Problem with Dragon Spirit!
edited March 2010 in Games
Hi folks.
I have a problem with Dragon Spirit (that shoot'em up game where you control a dragon instead of a spaceship).
I destroyed the final enemy I found in level 7 and the game just don't want to load the next level! It says "Well done!", the "virtual loading" starts and when it finds level 8 it blocks. The loading screen freezes, the frames turn red and that's it.
What can I do?
Thanks!
PS: I'm using ZX Spin
Post edited by Danae's Fan #1 on
  • edited March 2010
    I remember I had the same problem when making my rzx recording:
    http://www.rzxarchive.co.uk/d/dragonspirit.rzx
    Both .tap and .tzx files didn't want to load last level.
    Eventually I used .dsk file (Spectrum +3 disk image) and it worked okay.
    You can do the same, but it means playing the game again from start.
  • edited March 2010
    What can I do?
    Poke 49335,0 will fix it.
  • edited March 2010
    Excuse my ignorance, but how do I use such poke?
    (No, I didn't use pokes even in those glorious, "real speecy" days!)
  • edited March 2010
    In Spin, mid game, go to Tools, Poke Memory, type the big number into Address and the 0 into value then click Add and you are done.
  • edited March 2010
    Thank you so much guys, it worked. ;)
