Determining +3 revision
I have two +3's and have only just got around to inspecting the insides to look for the known +3 sound "bug".
The problem is that one machine appears to have a louder default sound output via the RF lead that seems to be distorted due to the volume. Both machines to my knowledge have not been modded.
Both +3's have a main board with "Revision 2" (IIRC) near the Amstrad name, which I took to be that they were +3Bs. Is this correct?
Post edited by brownb2 on
Also, I think that TR5 doesn't exists in +2A nor unbugged +3... in my schematics it has been renamed to TR200).
An' you know what they said?
Well, some of it was true!
Is there a non electrical method? I've just been looking to see if I have the bug and whether I need to invest in a multimeter and soldering iron :)
I've never seen a "newer" +3 release, so I don't know if that sentence is really true... but you may give it a try. Another method would be following the track to visually check if TR5 is connected to a 220 ohm resistor (red-red-brown).
Other method would be using a PC to check +3 sound output.
- First, find a program that generates a sine wave through AY.
- Load it into the known good speccy and capture the output (ten seconds or so will be enough) with the PC. Check the recording volume so it doesn't go above 50% (to leave "space" in case +3 is not buggy, only loud). In a wave editor (audacity), your sound must appear as a sine wave. Select only fractions of second, in other case you won't see the waveform clearly.
- Repeat the process with the other speccy, without touching any volume control. If the wave is not a sine one, but a clipped one... congratulations, you have a first revision +3 ;)
+3 Issue 1 Z70830
+3 Issue 2 Z70830
+3B Z70835 ISSUE 1 (c)1988
See:
http://tomdalby.com/retro/hardware.html
+3B I have never seen, but seems to exist in service manual.
Anybody to have one ?
I'm think only +3 Issue 1 has distorted sound and it is not related to presence of resistor in emitter output.
Analog circuit master to comment :-)
It would be useful if those people who fixed the +3 sound problem could confirm which version of the mainboard they had?
I got my +3 for Christmas 1987, so it must have been a very early example. It was in the Currys Live Ammo bundle. It always sounded like it was underwater, and because the sound came through the TV speakers it shared the problem that I had with my VIC 20, that is get the picture right and the sound buzzes, get the sound clear, and the picture isn't too good. Our TV didn't have SCART back then.
I recently got the AY magic sound module. I played Tetris and heard the same music that I used to hear when I played Tetris on my +3, but beautifully clear, and in Stereo. This is what el cheapo Amstrad should have done back then, but then I suppose it was an improvement on a beeper...
I never use the RF output on my +3 (infact, I broke it by trying to adjust that trim pot that's on it!). So I use the din to scart. The sound is actually quite distorted. But I don't remember it being quite so distorted when I used to use the RF output...
So maybe you won't notice the distortion because you were hearing white noise.
It's strange how the +2 was never affected by this sound bug. Didn't Amstrad use the same parts for the +2?
do you mean the +2A?
the +2 is nothing like the +3 except for the shape of the case.
Yeah, sorry I meant the +2A. I'm guess that the later +3's were released at the same time as the +2A?
