Don't Buy This TZX file on x128 emulator
I'm runnign this old DOS emulator on my old Win95 PC for Speccy Games (My main XP PC is for work, and bug-riddled to hell).
I've not used a TZX file before, and I'm not sure how to get games off it. I've read the help files with the emulator, but it only seems to find the first game 'Race Ace'. Does anybody else know how to get to the other games in the TZX file? I really fancy revisiting FIDO after all these years.
Thanks.
Thanks.
Post edited by Retro_eido on
eh?
i presume the tzx is a comp? as otherwise it prolly only has one game in it, if it does have more than one game on you can normally use a "tape player" section of an emulator to fast forward to the correct place just like a normal physical one
*thinks about turning his c90s into tzxs lol)
I have no idea about using the tape player function, if x128 uses one in the conventional sense.
I select the TZX, and 'unpause' it, then it loads the 'tape'. I have no idea or instrouctions on what else to do...:-?
ive no idea on the emulator, never used or seen it, on the ones i have used spin, spectaculator etc theres a little tape player section (play, record, fast forward etc) normally little buttons at the bottom of the screen or an option to open it in the menus
Press F1 to see the list of F-key menus and have a look at x128.txt for instructions.
Allready done that. Couldn't find anything about how to skip to different parts of the file :-?
From X128.TXT:
So press ALT-F7.
it's legendary status firebird game... I sold one recently on t'bay :D
but it's 5 AWFUL games.. but they aren't that bad.. considering some of the 5h1te thats been put out .. least this was a bit honest
http://www.worldofspectrum.org/infoseekid.cgi?id=0011245
