memory
edited June 2010 in Chit chat
probably a dumb question
i have 1gb memory in my PC, if i buy another 1gb memory (the same one i bought before.) and plug it into the other slot, does it just start working or do i need to do something else?
ive checked my specs and it can take 2gb.
Post edited by mile on
  • edited June 2010
    Plug 'n play with it.
  • edited June 2010
    You might have to tighten the jigger-bolts afterward but other than it should be all OK.
  • edited June 2010
    CUCHULAINN wrote: »
    nice one, its just i saw that PC world do it at store for you so wondered if there was something else you had to do.
  • edited June 2010
    ZnorXman wrote: »
    what are jigger bolts?
  • edited June 2010
    He's taking the piss. ;-)
  • edited June 2010
    CUCHULAINN wrote: »
    better to be safe than sorry, i'd have been in PC world asking them for some spare jigger bolts. :p
  • edited June 2010
    They are right next to where you seat your RAM. They are the only ones that look completely different from the rest of them on the mobo.
    Don't restart your PC unless you've tightened the jigger-bolts (a quarter turn clockwise for each stick of RAM, if memory serves correct)
  • edited June 2010
    i'll pm scotty.
  • edited June 2010
    dont forget to fasten down the flu and reposition your hatstands
  • edited June 2010
    i'll pm scotty.
    He'll tell you the same.
    edited June 2010
    you have to use the magic words and tap the case 3 times :)
    joking aside..
    go look on crucial.com ... that 80-90% of the time will tell ya :)
    then head off to ebuyer (given the spec) and look at the price.. then compare it to the prices of scan.co.uk and pcworld.co.uk
    both scan and ebuyer will prolly be cheaper :)
  • edited June 2010
    isn't it just the same thing i did when i put the first memory thing in? i weren't messing with screws when i did that.
  • edited June 2010
    Unless you have a very old system (say fifteen years or more*) then you won't need to do anything other than turn off the PC, (safely) insert the RAM, then just turn on the PC and the new RAM sticks will be detected and used as normal. Different motherboards have different tolerances of RAM stick differences, but as long as you put two of the same specification sticks in, and the amount of RAM now in the machine is allowed by your motherboard then you'll 99.999% likely have no problems.
    From what you've said in your original post (putting in the same 1GB stick next to the previous 1GB stick, and the motherboard supports 2GB of RAM) then you're certain to be OK. Bare in mind that "certain" in PC terms means "probably", but I've upgraded loads of PCs, and the procedure as you're doing it is as common and trouble free as anything is.
    When you've put the RAM in, boot up and go into the BIOS, and the information screen should tell you how much RAM the system has, so make sure it's the amount you are expecting. Let us know if you have any problems. And of course, beware of static, and only touch the RAM sticks on the ends, NOT on the chips themselves. The human body can carry enough static to happily fry any chips if you're careless.
    * Some very old PCs needed you to tell the BIOS how much RAM was installed, but that was back in the 486 and early Pentium 1 days.
  • edited June 2010
    ewgf wrote: »
    sometimes your long posts hit the spot. :)
    that exactly what i wanted to know thank you.
    when i put the thing together the motherboard specs siad it supported 2gb, but i only got the one to save money.
  • edited June 2010
    No, just a little hook thing on each side (each of the two far ends) of the slot, that hold the memory stick in place.
    There are three golden rules when upgrading a PC:
    1. Take your time,
    2. Look at what you're doing before you do it,
    3. Don't force anything, if it doesn't go in with reasonable force, then you're probably (though not quite always) doing something wrong.
    I used to teach people to build PCs, and there's nothing to it. They're (allegedly) put together by illiterate pre-teen children in the third world, so there's nothing complicated about slotting the parts together. Half of the chavs on the streets nowadays have built their own PCs, or can at least strip a nicked system down and canabalise it, so don't worry about it.
  • edited June 2010
    Yeah, that'd be embarrassing for the PC World 'expert' to have to call head office to find out the stock code for jigger bolts.
  • edited June 2010
    ewgf wrote: »
    1. Take your time,
    yeah its a quite an easy thing to do, i think the only thing i did wrong was wire my reset and power button the wrong way round. i made a large painful noise when i tried to power it on and nothing happened. but it quicly realised it was going to be the only cables that weren't color coded. :p
    edited June 2010
    quick pc world story..needed a case fan for something (in a hurry)... otherwise I'd not have gone in
    walk in.. where are the fans... the greeter shows me the desk fans *sigh*
  • edited June 2010
    fog wrote: »
    I assume life would've been better if there'd been some free jigger bolts with those desk fans :lol:
  • edited June 2010
    Right mile.
    See these slots. They may be a different colour on your mobo. Well if you have different colour slots just make sure your new memory goes in the same colour slot as your existing memory slot. In some cases it will not matter, but its better to be safe then sorry, if you have not got access to the motherboard manual.
    Notice the off centre key-way on your memory. Make sure you put it in the right way around or else this will prevent it from fitting in the slot. Also make sure the left and right teeth are open as you slot the card in.
    Once the card is in firmly the you should be able to click the teeth into the two semi-circular recesses in each side of the memory. It it has not clicked fully into place each side then dont turn on the PC.
    Once you are happy they are in but the PC back together and power it up. If all is well your PC should boot. If all is wrong the PC will beep and not load Windows.
    Once windows has loaded, right click the my computer icon and go to properties. You should now see your computer has more memory.
  • edited June 2010
    That guy is in for a world of hurt ... looking at those pics, it doesn't look like he has tightened the jigger bolts the right way around.
    Oh, and by the way, don't forget to get rid of any static electricity, touch the case, fondle it, caress it to make sure you've gotten rid of any elcetrogermsies.
    And also, it's sometimes easier to plop the RAM in from one side, i.e. gently seat one end/edge in, then press gently but firmly from the middle toward the other end/edge.
    Also-also, if you lean over the mobo case, make sure you don't have anything lose in your chest pocket ... that is if you are one of the few remaining persons on the planet who wears a sensible shirt, with a chest pocket. A mobo can take a bit of beating but there is no need to test it out by having a bunch of screws or a screwdriver fall on it ... from your chest pocket ... which happens to be placed on your shirt, somewhere nearabouts your chest area, usually right around where your heart is supposed to be ... so, either left or right side of your torso ... depending on the placement of your particular heart.
    Have a mice day, best fishes!
    El ZnorXie
    edited June 2010
    ZnorXman wrote: »
    so you mean putting on / off a jumper a lot isn't advisable.. then followed by some moonwalking over some static laiden carpet.. :)
    joking aside anti static braclet is a good investment
  • edited June 2010
    fog wrote: »
    Do this before any computer repair work:
    edited June 2010
    Znor ,it's funny as my friend is in the US currently and is bringing back some wild berry skittles (you can get em here BUT very rarely) .. I got some the other week from another friend who brought em back
    oh and I get Tiffen from Ireland one or 2 times a year :)
  • edited June 2010
    No offence Miles but i would format your hard drive if youre taking your PC to PC World ;)
  • edited June 2010
    On a serious note, you have to be a little bit careful with the RAM you buy as there are a couple (at least) different types out there. Namely DDR2 and DDR3 RAM and you'll have to ensure you are using the same type as one of them will fit the motherboard. They can also operate at different speeds, so if you insert one that is quicker than the one you have, it should operate, but will run at the speed of the slowest module installed.
    Your safest bet it to run the analyser on www.crucial.com and go with what that recommends. It's the Crucial System Scanner Tool.
  • edited June 2010
    Vampyre wrote: »
    yeah im just going to get the same as i got before. i have it all written down somewhere.
    thanks for that link.
  • edited June 2010
    Scottie_uk wrote: »
    A friend of mine says that if going to use dual memory (or what it now is called) make sure to use memorys of same type and same manufacturer or you're in for problems. I don't know how right he is but i follow that rule, he's smart about these things. I built a really good pc with the parts he ordered for me, not too expensive either.
  • edited June 2010
    Mind you don't disturb the chuntey field when you open the PC.
  • edited June 2010
    ZnorXman wrote: »
    Yeah people say that. Apparently static builds up in the Nylon really badly.
    Forget those nambi pambi wrist straps, or touching the case just do your install naked. :lol:
