Firefox vs Chrome?? Hmmmmm
I have both firefox and chrome installed on my computer...
I prefer to use firefox but for some reason I can not view the movies on bbc sport and can't see people's avatars on WOS with firefox
With Chrome I can...hmmmm???
Any suggestions?
Any suggestions?
Post edited by -RubberKeys- on
there are settings which will mess up on firefox.. I had to change a few on another forum... OR a clean install might fix it..
if you have a pop up blocker that might be another reason .. I have watched bbc things via firefox so know it's ok...
also maybe check for an update of your flash? or firefox in general..
there are 2 things, software and informer and filehippo update checker you might wanna check with
http://www.filehippo.com/updatechecker/
also if your going via a proxy or a none UK IP it knows .. that might be another reason
joking aside that made more inroads on macs?!?!
Forgot to click on "show avatars" in my options
DUMMY!
Using Google chrome for abit...
Better than Firefox???
Maxthon is probably the best browser I looked at though. You can find it at: http://www.maxthon.com/
Took me a long time to get away from IE. Can't believe I used the kludgy piece of crap for so long.
I like firefox, but i like chrome, but which is better ?? Only one way to find out.............
FIGHTTTTTTTTTTTTTT
I've usually got 5 or 6 tabs open for hours on end and I've got about 10 add-ons running all the time. Never had a problem.
But Chrome, bloody hell that's fast!
