In which case, try 6%, 7% etc. Apparently you can keep on trying till it works, they won't block your account.
Someone (unfortunately I can't find it now) did a fairly thorough analysis of it - he submitted hundreds of "music videos" to YouTube and did a pretty deep analysis. The more precise details can be found if you can find that web page. It could be the case that the song you used is more easily fingerprinted than others.
Thanks Winston, I'll be having another crack at that soon then. YouTube do let you try as many times as you want too, so that should be ok... Facebook definately don't let you try again and again, they sent me a rather stern message last time I tried. :grin:
http://www.csh.rit.edu/~parallax/
It seems that 6% is the magic number.
