ZX Spectrum style acrylic paintings
edited July 2010 in Announcements
If you were to buy an original hand painted painting which is a portrait of yourself or a friend or a loved one, how much would you pay?
Here's an example.
Here's the 2 illustrations I did for Edge last year :
Now, that's the style..but painted onto canvas using acrylics.
And here's an actual finished example completed last week :
Obviously, I've taken a bit of artistic license with a couple of the colours (the dull yellow, for example).
This image was 192x192 pixels in size and was painted on nine 8"x8" canvases making it approx 24"x24" in size. Each pixel is 3mmx3mm in size.
So, if you commissioned this to be painted, what would you pay?
Thanks.
Post edited by redballoon on
  • edited July 2010
    i dont think id be buying a painting of myself. :razz:
    erm, dunno, i painted some canvasses the other week and was flogging them at 20 quid each. (neither sold)
    i worked it out on material cost and time i spent on them. i guess what ever your happy to be paid.
    but they are very good non the less.
    i think you would be able to hawk them to non speccy fans as they do look contemporary.
    how about you do some famous people as an example. like famous people from the 80's?
  • edited July 2010
    Yip, the idea would be to sell to non-speccy fans too - the contemporary almost pop-art style allows that.
    ?20, eh? Not even close to the price I have in my head, particularly for the painting up there.
    Pricing will include cost of materials, time on painting and maybe some cost for courier to deliver.
    Bear in mind that it is high quality canvases and high quality acrylics, too. It's all about quality, man.
    So, for the above painting, the 9 canvases came to approx ?45 and the acrylic paints for the colours used in the painting - black, white, 2 shaded of yellow, magenta and cyan came to ?70..obviously, not all the paint will be used.
    Then there was the effort into creating the style digitally, then the 5 weeks painting.....as you can see, ?20 is not going to be an option (and never was in my head...;))
    And I wouldn't be painting them and trying to sell them, I'd be commissioned to do them, therefore they've come to me to get it done.
  • edited July 2010
    redballoon wrote: »
    i did both of mine in one evening. :p
  • edited July 2010
    Post pics please!
  • edited July 2010
    ZnorXman wrote: »
    Post pics please!
    im not hijacking this thread, i will do some more and post them another time. ;)
  • edited July 2010
    First time for everything I suppose...
  • edited July 2010
    BTW Redballoon ... cool pic ... may I ask what brand/kind of acrylics you are using?
  • edited July 2010
    It's not only about the painting itself, isn't it? To come up with a decent pixel image in the first place is already a lot of work.
    I would charge a fee based on the time it takes to produce such a piece, and go for an hourly rate that's not less than 40 pounds. And add the material costs of course. In that way you can always justify the price you ask.
  • edited July 2010
    ZnorXman wrote: »
    I use Daler-Rowley Cryla Artists' Acrylic.
  • edited July 2010
    redballoon wrote: »
    I use Daler-Rowney Cryla Artists' Acrylic.
    OK, thanks for that ... I prefer oils because I can take my sweet time to paint, instead of doing a hurried job with acrylics ... they always seem to dry out on me INSTANTLY!
    The ONLY drawback (in my humblest of opinions) with oils is the terrible smell.
  • edited July 2010
    I never hurried with acrylics. When I was doing the detail work then I only used a small amount at a time therefore minimal wastage and I would just clean my brush pretty regularly. It never bothered me if the paint got more 'sticky' as time went by.
    You can get the stuff to keep acrylics softer for longer.
    I use acrylics because of it's thickness and, when it's dry, it's pretty much indestructible.
  • edited July 2010
    redballoon wrote: »
    Maybe I just had a terrible "first-time-user" experience ... and I do recall it was a low-end brand of acrylics.
    redballoon wrote: »
    Que?
    redballoon wrote: »
    Agreed, I like to get a lot of physical/tangible "depth" when I paint ... I plop the layers on heavy-thick like ... just never got used to acrylics.
    ( and that's where patience comes into play because I more often than not wait for the layers to thicken/dry well, before I get the next layer on ... so yes ... I usually take [strike]days or[/strike] months to paint something)
  • edited July 2010
    Conversion suxx!!
    On the Spectrum so stunning graphics. Why did not you use it?
    For example:
  • edited July 2010
    newart wrote: »
    Conversion suxx!!
    For example:
    [LOTSA COOL PICS]
    Those pics are great, and would probably take a LONG while to paint the way redbaloon is doing it. Aside from that, they're the works of others, so it might rub ones conscience the wrong away around if one were to make money off of others.
  • edited July 2010
    Those screens are indeed great pieces of work, but I'd argue that they're working towards the exact opposite of what Redballoon is aiming for - namely, to recreate the 'Spectrum aesthetic' in a physical medium, complete with big pixels, primary colours and visible attribute blocks. Those things are all very prominent in a converted picture, while Speccy artists go to great pains to hide those limitations...
  • edited July 2010
    Acrylics? I'd charge between ?250-?400. No more, no less... Unless it takes you months to paint! You can pay that much for just digital art, so nobody should complain.
    If it's in oils though, well, stick another 200 quid on!
