Could someone please help me adjust my personal picture?
Not for this forum, as it displays okay on here, but the picture I use
could someone please adjust it so that it is
as I have tried and I have failed
thankyou :)
- No wider than 80 pixels
- No taller than 100 pixels
- File size smaller than 10 Kb
thankyou :)
Post edited by thx1138 on
its none of those??
paint says its attributes are 48 X 64
and its about 1.22 blah blah bytes
but what ive been doing for uploading pics for albums ive been uploading on a site is thus
1: copy a copy of the pic to desktop
2: open paint
3: file/open
4: browse for pic
5: click image / resize
6: change the horizontal / vertical %'s to like 50 / 50 so its half the size
7: click file/save
try and upload again, quick and simple only takes 2 minutes to complete
As above though, but edit it in something and save it without changes. Then it should upload OK.
i opened it in paint and saved it as a gif and it worked fine
I see it quite a bit (not here, I do forum support things for Invision), its something to do with the data in the image, so php does not think it is an image hence its rejected, but as you say in most cases, simply saving again 'fixes' :)
