Mainboard changing - windows problem
To a friend of mine has died his Intel socket 478 mainboard, we've changed it to a VIA chipset mainboard, we've solved all windows XP problems on new mainboard, except one. The AGP graphics card cannot be installed - the drivers, because of there is permanent conflict between graphics adapter and VIA cpu to agp controller. I've uninstalled PCI bus in safe mode, after restart it found new one, I've installed via hyperion chipset drivers, but the conflict still remains. The drivers of gfx card will smoothly install, but after restart the gfx adapter hasn't drivers. I can think only about one thing remaining, to uninstall old intel chipset drivers in safe mode, because in normal mode it won't show. I'm going to his flat just monday, so I can think what else it could be. In normal mode, in hardware device manager, the gfx card is marked with yellow exclamation, in safe mode the yellow exclamation mark doesn't appear. I'm suspecting, that old intel chipset drivers in XP do there something bad. Any other suggestions ?
PS: this gfx card was correctly working with this mainboard in other installation of windows XP.
PS2: I don't know, if by uninstalling PCI bus, the old chipset drivers were uninstalled too, if yes, then I have no idea what it could be.
Post edited by bohusk on
(1) if you can't disable it just set it to boot using the AGP first.
Unfortunately, it didn't help, there is still this conflict. Now I really do not have idea what it could be.
Can't remember if there's a way to manually assign IRQs like we used to a decade ago (before auto IRQ assignment became standard).
He just needs this PC to stand next few months, then he is going to buy brand new machine, because his son is pushing him that he wants to play games. The onboard vga chip is not suitable, because there is not driver for it anyway.
Describing how to do that and then trouble shooting it isn't something I really fancy doing on a message board :)
TBH the quickest way of sorting it would be to reinstall windows if that's an option.
I received by sms that it's MSI PM8M-V
I would uninstall the AGP card drivers, turn off the computer, remove the card, turn the computer on, press F8, start the computer in basic VGA mode and install the XP-32 bit VGA drivers found here:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=205
Alternatively you can also go here:
http://www.via.com.tw/en/support/drivers.jsp
And select Windows > XP > Integrated Graphics > P4M800
There you will find the latest drivers for that board, including the one for the integrated graphics.
PS: I never met with problem like this before.
If it was me in this position, I wouldn't have even entertained trying to shift one XP installation to a new motherboard without a clean installation.
