Speccy 48k Earphone jack problem
This is odd, today I set up my rubber key as normal, headphone out of the tape player into the "ear" of the spectrum, started everything off but nothing, blank grey screen, then i changed it to the mic socket of the spec and im getting loading bars and its finding games, (not, however, loading them, tape errors after the lead in, and no loading sound), cant understand whats going on, any ideas?
Post edited by Macc on
I had this problem at the VCF in June.... Until I realised that my "tape recorder" was set too low. Whap'ed the volume up and everything was fine.
There's very little in the tape input circuit of the speccy that could go wrong.
So my money's on poor/low signal or dodgy cassette lead.
spooky... the exact same thing happened to me.
The chuntey field was obviously strong in that marquee :)
Just to make 100% double-shure.
So, when the tapedeck is disengaged from the Speccy, are you able to hear sound from it (the deck) ? (if it doesn't have a built-in speaker try using headphones to make sure you can hear the sound)
if you know it's not the tape deck .. or the lead to the speccy
either re-tension the ear port OR replace it (on the one I have I think I have to replace it)
http://www.worldofspectrum.org/SpectrumRepairGuide/
I want to do the composite mod while the case is open , so didn't test if it works yet.. or I'd just get a replacement.
Jon
PS. Issue 3B just in case anyone asks. ^_^
Question though: does it mattere if the 3.5mm jack to jack is a stereo lead. I did make a mono one but that didn't work either. Just want tocheck the basics.
Can't wait for them to switch off the analogue channels so I can retune my Speccy back from the extreme end of the RF doohicky.
Or grounding the right-channel (red) lead.
Using a vintage tape recorder the solution??
I cannot seem to load using the split ear/mic cable. The screen border just alternates from red to cyan per second.
The speccy can save the file to tape okay (I believe because it shows the blue and yellow stripes).
I followed the steps in Chapter 8 Part 20 pp.163-164 of the +3 manual :p
I recorded the save via my laptop's MIC socket and then played it back after...
...but the speccy just displayed an alternating red and cyan border :cry:
Don't worry guys... I can verify it is the tape player that counts.
I plugged the earphone jack of the cable into a hi-fi tape player, pumped up the volume, and then at last the speccy picked up the signals...
...though I haven't had a successful load yet.
