Fitting UK plug adaptor onto ZX81 adaptor cable
edited October 2010 in Hardware
Hi all,
I'd like to fit a UK plug adaptor onto a ZX81 adaptor cable, there are 2 wires(blue,brown) and two connectors L,N. Does anyone know how to fit it properly in order to avoid any damage to my ZX81?
thanks,
Post edited by ZXMrk on
    edited October 2010
    which country is it?
    that comes into it also.. e.g. 110 and 240 volt
  • edited October 2010
    If there's no earth wire, as in your case, just wire up with no earth wire.
    Be warned, the first Google Images match for "UK plug wiring" is WRONG WRONG WRONG WRONG WRONG!!!!!!
    UK, iirc EU and UK is 240V but not sure.
    jgharston wrote: »
    thanks, I will do it according to the picture you posted. :-)
    Just remember b(L)ue = left, b(R)own = right.
    jgharston wrote: »
    I just saw that (only checked to see why you said that out of curiosity to see what was wrong with the first result) , that's really bad :( :-o :-o :-o
    spider wrote: »
    Ha, I just did the same. And judging from the 'b3ta' in the URL, I'm guessing that whoever put that image up knew exactly what was wrong with it... unfortunate accident for it to end up at the top of the search, or a particularly evil googlebomb? :-o
    gasman wrote: »
    work of genius I'd say lol, it's clearly designed to teach people not to fool about with mains electricity if they don't know what they'd doing ;)
    holy crap man that could cause a few little old ladies to meet their maker especially if it has a metal casing. Thats so irresponsible how come it is at the top result????!!!!?!?!?!?
    guesser wrote: »
    They won't do it again, that's for sure! :lol:
