Spectrum Joysticks...
Hi, this is probably a really obvious question to most of you but I just needed a little advice about joysticks.
I never owned a Spectrum back in the day (I had an Amstrad CPC - but let's not open that old can of worms :), but I've recently picked up a +2 on Ebay and am setting it up, getting some games together etc.
Now one thing I really need is a joystick - but the computer's instructions rather sternly tell me to use Sinclair joysticks only.
My question is : the joystick connection appears to be the same as for the CPC, C64 etc, so is it true I can only use Sinclair joysticks? Also, I notice a lot of joystick "interfaces" up for sale on Ebay. Do I need one of these to use anything other than Sinclair 'sticks?
Again, sorry for asking such an obvious question, but if anybody could put me right I'd be very grateful.
Post edited by stinkfoot on
A lot of the later joysticks that were available came with two D-pin plugs on the end - usually with one black and one grey lead.
I believe that the grey lead/plug is the one that you use for the +2 computer, using the 'SINCLAIR' joystick option
If you've just got a bog standard lead with one plug (Atari standard), then you'll need an interface. Kempston or compatibles (that use IN31 rather than a specific keyboard key) are usually the most easy to find. RAM interfaces are kempston compatible.
Beware though, as some interfaces don't fit with the +2 (normally the L shaped ones). You'd be better off getting a flat to the tape type one (RAM TURBO, Interface 2 etc.)
(For those as rubbish at soldering as I am, Maplin Electronics do D-plugs and D-sockets which use pins which you crimp on to the wires, then push into the plug/socket shell until they click into place... only trouble is, those can't be repaired, if a wire comes loose the only answer is a new one...)
misteaksmistrakesmisyaleserrurs— oh, sod it.
