Import text files of type ins
There are ways to read the text of scans and covert them to word or txt files. So you could do this then edit and correct them and import them to run and save. What do you think?
Post edited by MuZiKiLL on
But once you've got the listing in a text file, there are several tools that can convert that to a loadable emulator file: BAS2TAP, and my own preference zmakebas (which Gzavsnap has ported to DOS/Windows). I expect BASin can do the job with a quick cut-and-paste too.
It's just not accurate enough; even a 99% accuracy would mean that every line would still have to be checked for errors, and the mediocre to poor print quality of many listings, the fact that they're usually printed on matrix printers which type-faces don't OCR particularly well, that OCR is generally intended for interpreting human rather than computer languages and so often makes wrong assumptions about what questionable text should be, the readily misinterpreted 0/D/O - 1/I/l - 2/Z - 5/S - 8/B - all conspire to reduce the accuracy of the output. Then, whereas text in a human language can have loads of grammatical, punctuation and spelling errors in it and still be understood, text in a computer language has to be 100% correct before the program will run correctly. As for OCRing hex dumps - that way lies madness.
I don't recognise it, and I've checked the monitor programs which I have listed or on file and none of them look like that one. I also searched the code in case an author's name was in there but I couldn't find one. So I can't identify it, except to say that it did not appear as a type-in in any of the 1200-odd magazine issues indexed on TTFn. If it was a type-in, then it might have appeared in Personal Computer News or Popular Computing Weekly - a lot of those issues aren't indexed; or perhaps in a book - not my area.
It was Dr Ian Logan's DRAW An Arc routine, explained from ROM to BASIC. Ended up typing it in by myself (kinda short).
Used BASin to get a .BAS and then a .TAP.
The file sequence was: .JPG -> .TXT -> (BASin/Paste Code) -> .BAS -> .TAP :grin:
I think that with a better scan resolution (mag code font was smaaaaallll in those days!) and the OCR's spell check turned OFF, you could get somewhere. I still think there WILL be errors even doing so (heck, that's why code from mags never worked as one expected first try :evil: ).
Regards,
Marcelo.
I use "top ocr" results are hit / miss
Just to add <plug>that there's also an opensource linux/unix tool called bast, written by me, which also does this (and more!)</plug>. Actually bast can also be used on hex listings (with a XOR checksum of each row of 8 bytes. Hopefully I'll make the format more flexible in a future version). Though, as mentioned elsewhere, trying to OCR a hex listing is crazy.
depends on the quality of the original listing AND if there is checksums in the listing I guess.
using the 128's serial port to pc com1 etc.. I guess is a way.. and adjusting any ascii accordingly.
used to do same on c64, with 3.5 disks.. but you added or minused -$20 to the letters.. I forget , long time ago.
