Web Hosting recommendations
G'day chaps,
Question for you, there is a domain I've got my eye on, but instead of spending my hard earned loot willy-nilly on the first hosting company I come across, I was wondering if there is a particular company that you can recommend?
I've done some research and a couple of the big players (123-reg, fasthosts) have been universally panned by review sites. Are they as bad as made out, or is it a case of dissatisfied customers making the most noise whilst the majority are satisfied with the service they receive?
Any advice gratefully received.
Ian
Ian
Post edited by big_plums on
www.fogartyitservices.co.uk
</shameless_promotion>
Our work used to use Fasthosts shared web and SQL servers for about four years and never had a problem with them. You just need to ensure that everything you want to run WILL actually run on their web servers. For example, they won't install the M$ .NET Charting components on the servers so you're buggered if you want to use them in your web site.
We've since bought a dedicated hosted server from them due to expansion and it's awesome.
sounds like you dropped lucky as fasthosts are regarded with scorn in the industry!
any BS goes on , then you have the domain name and you can go elsewhere if need be.
someone I was gonna build a website for years ago, went ahead with out me.. ended up paying 5 times what I'd have charged.
Also - beware of sites that have searches for domain names as some will buy the name you search for and but it to sell on to you......
