The Never Ending Story (on a +3)
edited December 2010 in Games
I recently got a tape copy of The Never Ending Story, but it doesn't seem to load on my +3. Are there any known issues with this game and +3s/+2A/Bs?
It loads all the way, and then crashes.
Post edited by Alien 8 on
  • edited December 2010
    Is it the one that came with the original 128 ?
    Quick test: Try it in an emulator ? :)
    I'm on a temporary machine at the moment so little is installed otherwise I'd of tested it (each version)
    See here > http://www.worldofspectrum.org/infoseekid.cgi?id=0006740
    Could you have the 48K version I wonder ?
    Just installed Spin and quickly tried :)
    The 128 version works in both +2 / +2A and +3 mode.
    The 48 version only appears to work in a 48, the Speedlock falls apart on a 128 model.
    I've just tried it on Spectaculator in +3 mode and it works fine.
    If you do get it working that music will drive you mad after a while!
    Thanks everybody for your answers. It looks like mine is a dud tape then, or it doesn't like my tape deck (most games fine on it). I'll try a different deck and/or fiddling with the volume. If that doesn't work hopefully the person I got it from may exchange it for another copy or another 128K game.
    Macc wrote: »
    Dah, da-daah, , da, da, da, da, dahhh, da, da, daah da, da, daah, daah,
    Dah, da-daah, , da, da, da, da, dahhh, da, da, daah da, da, daah, daah...
    I never owned a +3 myself but I remember seeing it running in the early 90's on a mate's +3 (Jeremy Snaith's) without a problem.
