Testing memory/transistors etc with multimeter
Anyone have a rough guide to show how to do this properly? Im using the diode setting on the multimeter to test various components, im touching the black probe to the heatsink and going around the corner pins on the memory etc, getting some steady readings but i cant help think im wasting my time because im doing it wrong. Im not that experienced with a multimeter but I know if I figure out how to use it properly this increasing pile of dead speccys on the desk can only get smaller!
Post edited by Macc on
The diode setting is probably the least useful setting when testing a Spectrum. The diode setting is most useful when testing discrete components.
For basic Spectrum testing, start with the basic DC voltage setting. This will help you to identify the +5v, -5v and 12v which are so often a problem with the Spectrum.
Testing transistors in situ is more problematic. On a live circuit, you can only test their effect - you do this by measuring voltages!
For example, you can effectively "test" (for example) TR4 and TR5 by testing that the internal power supply is producing -5v and 12v when under load.
Hope this is enough to get you started. I'd suggest doing a quick search on the WOS infoseek section for service manuals: these will help you identify the correct voltages etc.
Of course, seasoned engineers will identify lots of more sophisticated tools you might use. But, for most common spectrum faults, a basic multimeter will probably do everything you want.
Hope this helps
Nx
Ill get a few schem's and take a look.
Thanks again and if anyone else wants to chip in with advice, feel free to do so, all help appreciated!
Any of the above seem right to anyone?
btw, no need to test voltages on each chip (sorry to state the obvious, just to be sure).
I've used it a lot I think it's based on a v2 board. I get different voltages on my 3b -not a lot though.
I've tried and indeed still try to fix em but unless it's lower ram or ula I've not succeeded. Very frustrating but I hope you get what you need from this.
Cheers
(btw, ram chips read -5v correctly too)
And differences in temperature among the chips are generally a bad sign.
The problem you meet here is that not all is solved by just measuring, interpretation of measured values is another thing! You did OK when measuring the (steady) supply voltages, that's a good start!
