zx81 rf output
Hi All
I'm not sure if this is an appropriate forum for the zx81, however I'll ask anyway;)
I've connected my zx81 up to a mid 90's color tv. I can tune it in and I can get a fairly clear picture. However it is very dark almost black. The text and K cursor have a bit of whiteness around them that fades off toward the right.
I can read everything but it is pretty ugly. I remember the screen as being white with black text, the last time I used it (literally about 25 years ago).
Is it using some dodgy way of producing the picture that doesn't work with modern tvs?
Cheers
Cheers
Post edited by wozname on
http://www.rwapservices.co.uk/ZX80_ZX81/forums/
However, the issue you describe is due to the ULA used in the ZX81 - there was a later ULA which fixed this issue, although it is nearly impossible to find now (and most ULAs on the ZX81 are soldered directly to the motherboard, so not an easy fix).
www.rwapsoftware.co.uk
www.sellmyretro.com
The composite mod is possible and its the same as on the Spectrum, i've done it on ZX81 and Timex1000.
http://www.trademe.co.nz/Computers/Vintage/auction-345961369.htm
I don't know if the composite mod would help, I vaguely remember that the zx81 used the z80 itself to generate the video signal. Thus the reason you could run it in "slow" mode and see a display or in "fast" mode with no display. I suspect I would just get the same image but coming through the composite plug instead of the rf plug. In other words, if the underlying image is screwed, it doesn't matter how you transmit it.
I suspect that the old tvs were just more accepting of screwed up input signals. I wish I still had my old black and white 1980s set so I could prove this theory.
Thanks for all your help
Cheers
Since I don't want to mod my zx81, I'm hoping maybe there is a postprocessing solution. I will probably have to do the composite mod though, in order to get a signal to postprocess.
Cheers
I wrote an article where you can read about this problem ( sorry, only in spanish)
http://trastero.speccy.org/cosas/JL/ZX81-ULA/ZX81-video.html
The "blacking level" was not implemeted in first ZX81 ULA ( ULA 2C184). The "good" ULA is the 2C210 model.
There are some solutions (sorry again, only in spanish)
http://trastero.speccy.org/cosas/JL/zx81%282%29/ZX81-video.html
The first circuit add "blacking level" to zx81 video signal.
Other solution is invert the video signal ( black screen and white cursor ). I put some example of invert circuit
Bye
Jos? Leandro
Routing that directly to the outside world is a good way to kill the ULA's video output. It does work though: last time I tried, it gave a sharp but low-contrast (greyish-black) image.
Better is to replace modulator circuitry with a transistor buffer like this: www.zx81.de/english/video_e.htm
My TV also preferred a capacitor in the signal (+ to transistor output, - to center pin of outgoing connector), which may not be necessary. I used 47uF, better is 100uF (or more?). On my ZX81's, image is a bit less sharp this way (compared with straight ULA -> comp. video input on TV), and sometimes there's a little distortion depending on screen contents (big black & white bands causing the border to become non-linear in places), but overall the image is very good and black & white levels are excellent / as they should be.
Above transistor buffer (+ capacitor if used) fits comfortably inside the modulator case.
I double that....
I used this cirquitry with a 100uF capacitor to the video out. Excellent picture.
I was wondering if I could also use the same cirquit board to get composite signal on a QL, since the QL uses the same modulator kit as the ZX Spectrum and the ZX81.
Yes I know the QL has an RGB out, made a cable for that too but I would like to have the composite out as an easy and fast connection on a tv option.
I found another back porch generator circuit at Paul Farrow's site:
http://www.fruitcake.plus.com/Sinclair/ZX80/VideoGeneration/ZX80_BackPorchGeneration.htm
