Graphics card question
I'm currently running an Nvidia Geforce 8600 GT card in my PC.
I've been playing GTA IV over the last day or two and every time when i've finished playing it i've ran a scan on my graphics card temperature and it's always around 60-69C. I know GTA IV is quite a high spec game but this temperature seems way too hot, i've stopped playing it for the moment as i don't want to damage the card/system.
Is this temperature normal for a graphics card? (i've checked the fan and it's working fine). My CPU and hard drive are at 27C and 34C which seems more normal.
Post edited by zx1 on
Might be worth changing the airflow through the case to lower the temps a bit with an extra fan.
My graphics card (9800GT) can run easily at load to the high 70s with no issues at all, so your graphics card is running pretty cool to be honest.
wow! 96C is something like 180F!
Trust me, 69C is not hot at all for a gaming graphics card. Doing a quick look at your model card around the net shows many gamers with temperatures reaching 80C and over. These cards were designed to perform to high temperatures, and although the cooler they run, the longer they last (as is true with all computer equipment), you are using it well within its operational design.
So stop worrying about the card! I would suspect that if it was faulty, it wasn't because of heat, more likely a physical fault or a driver/windows issue.
GTA IV has a texture bug that does exactly what you describe on many systems including my own over a period of time. Google for "GTA IV texture bug" or some similar search term. It's nothing to do with your perfectly fine card temp :)
Furmark stress test can push my GTX 260 to something like 82C after a few minutes from an idling temp of around 40C. High 60s to low 70s is more like the gaming norm.
Yeah, this has even happened to me on the 360 version a couple of times, so probably not anything to do with your card....
Just me getting my knickers in a twist as usual!:smile:
I remember Batman: Arkham Asylum doing something like that, on purpose, during one of its early cutscenes and I thought my Xbox 360 had over heated or something. But no, it was just a clever stunt...
Yup. My GTX260 regularly hits 80+ when playing Crysis at insane levels of detail :-)
I nearly had heart-failure when that happened on my PC with a newly installed GFX card...
Yep, that got me too :lol: A great standout moment from a great game :)
