IIRC, if you don't have a modified ROM with a TR-DOS-shell built into it, you need to do RANDOMIZE USR commands to hook into TR-DOS.
Someone'll probably tell me I'm talking rubbish tho.
If you've chosen to have TR-DOS enabled, you should have a seperate TR-DOS option on the first screen.
When you're in:
LIST (K) gives you a directory listing
LOAD (J) "nameofprog" loads the named prog.
other stuff I can't remember offhand - I'll have a look when I get home.
EDIT: I assume MERGE works in exactly the same way as usual, but SAVE support has to be built into whatever you're loading, unless you fancy doing some RANDOMIZE USR's.
Cristi
When you're in:
_________________
http://www.slitscan.tk
Insignians Destroyed! I Have Won!
[ This Message was edited by: b00mzi11a on 2004-10-15 19:12 ]
