Amstrad CPC users...help?
I'm in need of a bit of help. A programmer has some CPC software on disk that need transferring to tape, so he can get the games released on the Cronosoft label.
I don't have a working CPC with disk drive at the moment - is there anyone who could help me out?
In fact, it would be even more ideal, if I could get it across to an emulator, so I can make a WAV file.
_________________
All the same we take our chances
Laughed at by time
Tricked by circumstances
Plus ca change
Plus c'est la meme chose
www.CRONOSOFT.CO.UK
[ This Message was edited by: chaosmongers on 2004-10-15 01:42 ]
Post edited by chaosmongers on
  • edited October 2004
    Well, I don't have an actual CPC handy (you could try asking in comp.sys.amstrad.8bit)but I'll just point out that the +3 can read CPC format disks so you should be able to use one of those to transfer it, assuming you have one that is!
    Why not ask one of the STP/SDP people to transfer the data to a image file? One of these kind people are goign to extract the files from some CPC 3" discs for me (which I'm donating to this worthy cause)
    Yep,
    Send 'em on over :). I can dump a EDSK image with my P75 with a 3" drive connected and usual drive adaptor:
    http://newton.sunderland.ac.uk/~specfreak/FD1/
    http://newton.sunderland.ac.uk/~specfreak/FD1/GPsAdaptor
    From here it's possible to use the images in an emulator or even mount the image and extract the files needed.
    I can probably do whatever is needed to be done to get the data to you.
    Just drop me a PM and I'll be happy to help you out.
    Best wishes
    Andy Barker (ZX Spectrum Preservation Project Manager - http://www.specfreak.co.uk/ )
    Thanks guys! I'll contact the programmer, and as soon as I receive the disk, I'll be in touch.
    What a nice bunch of people :)
    Hey Andy, I won a 'new' 3" drive on ebay last year. I finally opened the package today and lo and behold, no adapter required :D
    Drive has a standard 5.25" drive connector and standard power connector. Just needed a floppy cable with the 5.25" as well as the usual plugs on it from Maplins.
    http://www.spectaculator.com/download/misc/3inch-002.jpg
    Cheers,
    Jon.
