Basic info about platformers...
edited October 2004 in Development
I have run a search for an answer to this question and haven't found quite what I was looking for so I thought I would pop a post on here...
What are the general rules about designing and coding platformers (eg JSW)? I have tried messing around before and while getting a character to jump and move around isn't too difficult the bit I find hard is coming up with a system for the platforms.
How is the player character's collision detection done (how do you know which part of the player has hit a platform?) What about the platforms themselves, is there a standard way of giving them their properties and again, how do you detect for the top and bottom of it?
I'm just looking for general info, psudo-code even. This isn't for use on the speccy itself so I don't have to worry about saving memory etc...!!
Thanks to anyone who can help!
Post edited by Scoops on
  • edited October 2004
    Your question is basically about collision detection.
    One of the simplest way to do collision detection is by doing what is called a bounding box collision test. The bounding box is simply the smallest possible rectangle (in case of 2d sprites) that encloses the entire sprite. In case of a simple 8x8 sprite, the bounding box would be 8x8 too.
    The bounding box for each sprite can be maintained in a structure. A simple sprite structure can be something like this:
    The bounding box info can be maintained as a structure like this:
    struct RECT {
    int x1, y1; //top left of the box
    int x2, y2; //bottom right of the box
    That's all the info you need to compute the dimensions of the box.
    The sprite structure then holds a RECT attribute within itself, which will act as it's bounding box:
    struct Sprite {
    int x, y; //current position of the sprite
    RECT BoundingBox; //collision rectangle
    IMAGE* img ; //the link to the sprite image
    After this you just derive different character sprites from the Sprite struct (you can use a class if you want OOP's) like:
    Sprite player, ship, table;
    At the time of initialization of the properties of these sprites, you compute the bounding box for each of the sprites, which you'll use subsequently for collision tests.
    As for the tests themselves, you simply check if the bounding box of one sprite overlaps another. If they do, you have a collision.
    The problem with this kind of test is that it may signal a collision even if the sprite pixels themselves do not overlap, because the bounding box is an approximation of the shape of the sprite.
    You could use pixel overlap tests to actually fine tune the collision. The usual way is to do bounding box test to quickly sort out non-collisions, and then do a pixel overlap test (if you require that is) to do a more accurate test.
    You can find more info on the subject in this article on gamedev:
    http://www.gamedev.net/reference/articles/article735.asp
    My website contains a lot of technical (and other) information about Manic Miner and Jet Set Willy - including collision-detection - which could apply to platform-games in general.
    Dr. Andrew Broad
    http://www.geocities.com/andrewbroad/
    http://www.geocities.com/andrewbroad/spectrum/
    http://www.geocities.com/andrewbroad/spectrum/willy/
    http://groups.yahoo.com/group/manicminerandjetsetwilly/
    Just reading through the JSW collision detection info... I have never thought that the order in which objects are drawn on screen would be so important in a platformer. Is this due to technical reasons at the time or does this method still hold true today?
    I think it's just down to the way it was written. I know one of the things it says there is that in JSW, guardians colliding with each other will kill you*. This is true for JSW, but not for JSW2 - or Stay Kool either come to that.
    edit: *actually it only says that by implication, but it is true (& mentioned in most JSW editors)
    [ This Message was edited by: darkman on 2004-10-17 21:42 ]
    On 2004-10-17 21:10, darkman wrote:
    I think it's just down to the way it was written. I know one of the things it says there is that in JSW, guardians colliding with each other will kill you.
    Actually, it's if a guardian collides with *anything*, you'll die. That caught me out on my first attempt, and in all the games I've made using JSW editors, I've had to make sure that guardians don't collide with anything at all.
    Isn't this how the Attic Bug screws the game up - after the arrow crashes through the memory doesn't it change lots of room data & cause collisions that weren't there before ?
    Mind you, the room data also gets corrupted by visiting the 'illegal' screens by using writetyper or pokes but I don't know why that happens.
    By the way, are any of your JSW games available on line ? Must be better than anything I could do !
    [ This Message was edited by: darkman on 2004-10-18 00:41 ]
    Nope, they're not, and Nope, I doubt it :)
    My little 'un likes them, but I've got the only copies and it's staying that way :)
    As far as platforms go, you`d be well suited to knock up a simple map editor, this could be used in multiple games in the future as well, so won`t be a waste of time, and is pretty essential if you wanna be doing platform games.
    What it does is be able to load in the graphics that you`ll be using for backgrounds, and platforms, which are stored as blocks of 16*16 usually if it not spectrum, or 8*8 for spectrum... you then are able to move around up/down/left/right 8 or 16 pixels at a time placing the graphics blocks - whilst you map data is updated.
    You load in your generated map data into the game, and read value`s for what block is pasted where, for static screens, and also scrolling, and it has the added advantage of also letting you know when the player is standing on solid platform, or when he`s walking /jumping if he hits/walks against a solid block...
    It`s best to group the order of your graphic blocks so say the first 200 are normal background, say 201 to 230 are for diff` types of platform, and 231 onwards can be special things like spikes, transport blocks etc
    by grouping them like this it`s easier and quicker to test the value`s around your character... like if mapdata(posx,posy)<=200 then `it`s ok to run about, fall through, jump through these areas...
    If the mapdata is on platforms you know what to do, and because you have say 30 different blocks available for platforms, you can accomodate different graphics, but also effects... i.e. invisible platform, used by having a background graphic, that is given a number between 201-230... or crumbling blocks (not forgetting to update your mapdata from within the game, if summit crumbles)....
    Also, you have your dangerous blocks which kill, or transport you etc etc
    I cannot encourage you enough to write a decent map editor, it`s much easier than the actual game code, and will give you as much use as most any other thing you`ll code...
    Best ofluck :)
    Oh, and whatplatform will you be using, just outa interest?
    Something else that might be useful to anyone writing a platform game is to take a look at Jonathan Cauldwell's mini game entry Area 51, which comes with fully annotated source code.
    The easiest collision detection for the ZX Spectrum is offcourse to make all items on the screen another PAPER/INK color than your character. If you wnat to place your character on the screen you simply test the ATTRIBUTE of that position with your color.
    If there is a collision, then you test whether the printed items overlap. If you only work with PRINT AT positions, then the ATTRIBUTE is enough (or the SCREEN$ with altered characters)
    Then I've tried to write my first game for Spectrum 12 years ago I also come to collision detection problem. I used Basic, and my first try was to use SCREEN$ function to receive a symbol from screen. That worked, but a mase drawn with standard symbols looked ugly. After a long recearch I've found an ATTR function which could read colors from screen. So I've drawn a screens using one single big PRINT operator with different colors for walls, moving platforms, collectable items. That time I didn't understood why all type-ins from computer magazines stored all level desing using DATA operators with numbers - that was so hard to read and edit. Only later I understood a model/view separation principle
    Thanks for the info CKay. I have made a few attempts in the past but time and motivation often stand in the way. Even so, I think it is always a good way to get you into a new language. I have made a few attempts using BASIC (the furthest I got was using METAL). I totally agree about the level editor thing. It makes sense if you are trying to make a lot of screens and improves you programming skills at the same time.
    The platform I am working on is the Mac. A format that hardly ever sees a remake, a great shame...
    I hope you reconsider your decision to suppress them. Over 60 Spectrum MM/JSW games have been released by now, but we could always do with a few more! :)
    Dr. Andrew Broad
    I agree, but luckily the Head over Heels remake *is* available for the Mac. :)
    How different do they need to be? I've got JSW 128 with the April Showers screen added, & Woody's fast version with April Showers & some of the unique screens from JSW 128 added.
    I have "Tidbits" sections in my List of MM/JSW Games for minor variants, games with just a few rooms edited (e.g. less than 25% of the rooms), or which otherwise don't count as true new games IMO.
    Dr. Andrew Broad
    http://www.geocities.com/andrewbroad/spectrum/willy/list.html
    Yeah, that sounds about right. I've sent them, along with some Italian hacks from the Tipshop Italian Project page.
    Also available is oolite an excellent Mac remake of Elite - the bestest game evah in RetroGamer's reader's poll.
    Yes, I have played the Head Over Heels remake in the past and just downloaded Oolite. Any other mac remakes though??
    there seem to be some more at:
    http://www.remakes.org/
    Despite being poohed on for suggesting this last time and having never actually written a platformer, I would be very tempted to organize each screen as a state machine.
    Each state of the state machine is a single rectangular box with rules:
    1. The "ground level" of the box. If player jumps, it stops falling at the ground level.
    2. How to leave the box. If you go off the left side of the box, you move to state N. If you go off the right of the box, you move to state M, etc.
    3. Things in the box (eg, power ups etc).
    You can make each state as detailed as you wish. The advantage is that your program only has to make computations about collisions, etc, based on a single state's characteristics, rather than doing collision detections on everything in the screen if a table is used.
    And, state machines are very, very easy to deal with. They make programming so much easier.
    That's my two cents.
