Scottie_uk wrote: » What key benefits does it bring? any new features?
RND wrote: » Ive had it since it was leaked and have had no issues at all.
I'll check windoze update later and apply it if it asks.
EDIT... Ah yes, three updates listed (1 optional) , * clicks * , 87MB
If I've not posted back in an hour you can assume it exploded.
I'm running Win 7 Ultimate 64bit.
Updated OK, took about 2 maybe 3 minutes to config itself after a reboot but otherwise seems OK.
Using 7Pro 64
Not sure on 'features' though.
http://technet.microsoft.com/en-gb/evalcenter/ff384134.aspx
Colin
I update all the time, so found it odd that it's chucking a hissy fit
Hope it wasn't raining at the time :p
it was at the time :p
