reinstalling an athlon xp heatsink
fogfog
edited March 2011 in Chit chat
ok, I've got an old cpu that needs it's heatsink sorting.. it's an old athlon XP , but the stuff on the heatsink needs replacing.. as the bit where the chip was resting has worn thru
so I got some thermal grease + pads
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280642889228
the pad looks like sticky tape, is that right? whereas the old compound on the cpu itself is different.
obv. I need to clean the chip / heatink , but I am just worried that pad is the wrong thing.
and if so, whats the compound to use on the heatsink, it's a square. (not the thermal grease)
thanks.
this confuses me more.. as it says not to use both.. but the tape looks like I got off the ebay think, looks like well it;d melt
Post edited by fog on
  • edited March 2011
    I would simply clean both the CPU and heatsink of any previous compound/pads and then use silver thermal compound. Just a little on the cpu, spread thinly and evenly over it, and place the heatsink on top. Job done.
    Maplin sell silver thermal compound fairly reasonably (about ?9 IIRC).
    edited March 2011
    I have this paste as well
    http://www.ebuyer.com/product/126410
    but well like most I've only just stuck on a heatsink and done with it.
  • edited March 2011
    Throw the pads away, use some IP to clean the old paste off and fire her up :smile:
    EDIT: after putting a little past on the processor of cors.
    edited March 2011
    IP ?
    that the head cleaning alcohol.. someone suggested lighter fuel as well. maplin sell some cirtus cleaner stuff
  • edited March 2011
    fog wrote: »
    IP ?
    Yes thats right
    http://www.tmbelectronics.com/index.php?main_page=product_info&products_id=327&zenid=9e458197d4f1d2d359149323d7205563
    I dont think chemists sell it any more now though. I have a big bottle of the stuff to clean electrical connections also the heads on my tape recorders.
  • edited March 2011
    Lemon juice works well to clean old paste off.
    You need about 1 drop of the silver paste and spread it (very) thinly on the chip. Don't be tempted to put loads on, it doesn't work as well. Only put the silver on the chip or the cooler, not on both. The chip is easier as you know where the full contact area is.
    If you really want to do the job properly then you should lap the chip and cooler but its not worth doing that for a low end setup, it is, however, very relaxing in a strange way.
