Twin port joystick interface
Did anyone ever release a twin port joystick interface that (for example) had one port for "Sinclair" and the other for "Kempston"?
I'm looking for a way my wife and I can play Gauntlet (and possibly other games) using 2 joysticks, on a 48k.
Post edited by Mousey on
http://cgi.ebay.co.uk/Dktronics-Dual-Joystick-Interface-Spectrum-/160566843455?pt=UK_VintageComputing_RL&hash=item256287983f
Dktronics one
Ram Turbo
One of those is available here
Hope that helps!
[EDIT] I found another - the Kempston Pro Joystick Interface - but I didn't know they were on WoS until Macc posted those links (shame on me!).
I wonder if this might also do what you want? :)
http://cgi.ebay.co.uk/Sinclair-Interface-2-/200592424316?pt=UK_VintageComputing_RL&hash=item2eb43d7d7c
Two of them are Sinclair types, the third operates the Kempston joystick protocol but also operates the cursor keys at the same time. Which means you can't use either of the Sinclair ports with the Kempston one.
If anyone knows of a way to nobble the circuit so it doesn't do cursor keys then I'd love to know. Why couldn't they have just put a fourth port on it? Or had a switch or automatic change-over when you switch on or something?
I'm after one that can use Sinclair and Kempston ports at the same time.
Contain 4x joystick connector and is programmable. Joysticks can work as:
Q,A,O,P,SPACE
Q,W,E,R,T
Sinclair 1 (6,7,8,9,0)
Sinclair 2 (1,2,3,4,5)
Kempston
Fuller
Cursor (with shift)
Cursor (without shift - only numbers)
And is possible connect also PS/2 mouse (k-mouse)
Good point! ... was just curious as to why you hadn't mentioned the IF2 itself, since you mentioned the 'Sinclair' interface. :)
I guess a Kempston + Sinclair interface would support more games, though.
My other thought was a DISCiPLE, but... hrm ? maybe not? :p
