Joystick Interfaces?
OK, forgive me if this is a dumb question, but...
I bought a +2 Speccy a little while ago, and I've been struggling to find joysticks that work with it. I have a Speccy specific 'stick but it doesn't work properly, so I decided to get a joystick interface so I can use my other joysticks.
I bought one (again on Ebay) but when it turned up it wouldn't connect to my +2 - the only place I can see where it would go is in the expansion port at the back, but the interface connection is the wrong size to slot in there and there ain't nowhere else it could go!
My question is this : Was there a different type of interface for the +2 models? Or am I doing something wrong?
[ This Message was edited by: stinkfoot on 2004-10-29 12:50 ]
Post edited by stinkfoot on
<A HREF="http://www.worldofspectrum.org/forums/viewtopic.php?topic=3830&forum=4" TARGET="_blank">
see here</A>
Cheers for that!
So did you end up buying a joystick interface then? Cos I'm finding that Spectrum-specific joysticks are very hard to come by, whereas the standard Atari types are everywhere...
Or do as I did, and make one yourself
ftp://ftp.worldofspectrum.org/pub/sinclair/magazines/SinclairUser/Issue056/Pages/SinclairUser05600103.jpg
I asked the same question in CSS, and got this answer:
http://groups.google.com/groups?hl=en&lr=&selm=9mb765%2417anq%241%40ID-89047.news.dfncis.de
