BitTorrent - some questions
Ok, I've heard quite a bit about BitTorrent now and have read up some stuff on it, but I still need some answers on this one. Since many specchums seem to be using it I thought I might get some relevant replies here:
1) How well does BitTorrent work for low bandwidth users? Like say someone on Dial-up. (Me!)
2) Just how different (better?) is it from P2P like Kazaa? I understand the sharing model, but I'd like to know if it actually works as advertised or are the gains marginal?
3) Which Windows BitTorrent client would you guys recommend (assuming a dial-up user can use it)?
Post edited by Arjun on
http://azureus.sourceforge.net/
Very similar to eDonkey and very userer friendly.
Go to a BitTorrent sight, select the file, save and it automatically get added to Azureus. Work similar to eDonkey where you d/l segments from seeds and pier servers.
I use Torrentstorm for my downloading needs. Very easy to use, and loads of features.
most ive tried dont start, get client errors, slow downloads (im on dial up) and i hate having no user interface to throttle, stop, start downloads, search, save to etc
ive tried using bittorrent a few times and im currently downloading the imagine docu dunny posted which should take about 6 hours to complete, its the first one thats even got close to halfway, im on 57% at the moment.
i try torrent for these retro goodies not readily available on other networks but tbh im gonna stuck to my old friend winmx :) i can do a lot more with the interface.
Better go get broadband Mel yer tight arse ;)
Jon.
I've only tried BT Shadow's Experimental and I still use it but now there's BitTornado. It does work well for me. Alot of people like Azureus. I'd say give some a try and see what works best for you. You may have seen this already but in case not check it out;
http://www.halm.us/bthq/clients.html
Cyborg is right. So if you are looking for something in particular which was released through torrenting and it's not being seeded anymore, you can often times find it being shared after on emule/etc. Sometimes if the demand is high enough it will be torrented again so check out the torrent sites.
In my opinion Kazaa is almost worthless. I find it's better than Torrents, and probably emule, for Music mp3s and "maybe" some of the most common programs, but that's about it.
I use Azureus which is a very nice Bittorrent client, although the latest update is either buggy or hasn't installed right on my machine. The menus are messed up.
I've been using for a year or two now and I only ever go back to K or Ed when I really want a rare file.
BT is best designed for getting the latest thing as quickly as possible. Anything older than a week is a dead torrent basically so you have to keep a finger in the pie and make sure you don't miss anything.
As a user of Napster, then Scour, then Kazaa, then Edonkey then Emule I can honestly say for speed nothing remotely beats BT for leeching off the net.
Oh and since it forces everyone [in theory] to upload it's the fairest.
Oh and since in order to find out who's downloading the files you have to start downloading the files its pretty well defended from the authorities. After all if they know your IP address, then the only way they found out is by getting in the queue themselves! :D
It's quite ingenious and I do believe so clever it should be banned!
I totally disagree. On my copy of torrentstorm I limit my upload rate to 3K per sec and it's had no effect whatsoever to the download speed of my torrents. As long as there are Seeds and peers I get my usual 55k per sec (approx) download speed.
1) I have Sygate firewall installed. Will it interfere with BitTorrent? If so, how do I work around it without compromising on security?
2) What on earth is seeding (fnar!)?
2) seeding is a user who has finished downloading the file and is only uploading it. If you leave your BT client open after it's finished downloading something you are a seeder.
Simple stuff really :)
COS THERE IS NO BROADBAND ROUND HERE :)
or cable for that matter
so its not a case of tightarse, its a case of desperate for BB but gotta wait till march till BT should be upgrading the exchanges
Well thats Yorkshire for you. We've had Broadband here in Lancashire for ages. ;)
Appaerently in the depths of Yorkshire it's only recently that Dialup has become available, folks used to have to post stacks of punchcards to their ISP or send packets via semaphore to leeds where they could the whistled into a phone.
some still cant get channel 5, no broadband, no cable and were just getting gas installed round here :)
Do they have running water in your area?
fancy a holiday here?
There were old mid 80`s tins of beans in the window of their only shop.
I peddled very fast...
I`d say what it`s called but someone`l come on and say, Hey, you Bast, I live there, he hee.
You've missed the entire point of my post. The point of BitTorrent is to GIVE as much as you TAKE. If you download 100 megabytes, you give back a 100 megabytes, or as much as you can manage. The best way to do this is to upload and share as you're downloading, by allowing as much upstream as possible to be given. With my 512kbps broadband, I have a 58K download to 27K upload limit. Thus after downloading I still have a long wait to upload. As any Bittorrent sharing site will tell you, you should aim for a 1:1 sharing ratio so the service doesn't suffer.
I'm not saying if you choose to be selfish and download at 55k/sec and upload at just 3K/sec you won't get the same fast download speeds, just ideally you give back as much as possible. As the original poster has a mere dialup modem (with probably 5K bandwidth), ideally he would be sharing some of that bandwidth towards uploading, thus his downloads wouldn't be as fast as could be found with certain other mediums - thus Bittorrent isn't ideal.
I sincerely hope although you are downloading many times faster than you're uploading that you are still giving back as much as you download. One of the most annoying things on BitTorrent is when you are seeding and spend ages making sure someone finishes their downloading so you can go - and they just log off straight away when there's another 30 people waiting to complete the download.
Anyway, whatever the speeds, people should make sure they're still sharing as much as downloading. I can't understand why Starglider has limited upload to just 3K??
I totally agree with you - people should leave the upload as open as possible on torrents, otherwise the whole thing's a bit pointless. Fortunately lots of torrent sites now disable your download if you sit about leeching.
EDIT: As a test, I've made my Sinclair QL games folder a "shared contents folder". Is this the right way to go about making stuff available to other people? Or is there a better way?
_________________
"48K ought to be enough for anyone!"
- Sir Clive Sinclair
[ This Message was edited by: Arjun on 2004-11-12 19:01 ]
I won't go into it, since there are a stack of websites you could google to find out how to do it exactly, but that's the most basic explanation I can come up with.
