+3e 8Bit IDE (how to get snaps onto the HD)
edited July 2011 in Hardware
Hello there my fellow WoSer's
I have been playing around a lot with this under-emulation as well as building some prototype IDE interfaces.
I would like to get snap-shots on the simple-8bit interface, but I am having a bit of a face-palm moment in getting them to the disk (CF Harddisk)
Now using the DivEN +3e ROM, (DivIDE +3e ROM) and the DivIDE (16bit IDE) I have been able to format and partition a 64MB CF Card and put snap-shots onto the unit with 3e strowstraw (+3e File Browser ) - It wascertainly a joy to type the following on a taget machine (my +3)
SPECTRUM "C:SCRUE128.Z80"
And in under 15 seconds the game fully loaded at the intro screen =)
However, its the 8bit version that causing me a bit of a problem. Unfortunately 3e strowstraw wont allow for half-cluster size, so HDF's made under the 8bit IDE +3e ROM are not compatible..
So how do I get a multitude of snap-shots onto this 8bit formatted device?
What have I tried?
I have used eightyone to create a 32MB HDF, using the SM8EN +3e ROM.
I have sucessfully partitioned created basic programs, loaded and saved etc. I have also been sucessfull in using a pre-prepped tools HDF.
What I need to be able to do is
1. Add snapshots to an 8bit +3e (half-cluster) formatted HDF
2. Add snapshots to an 8bit +3e (half-cluster) device.
Any help / ideas would be welcome.
Thanks for reading.
Post edited by Zetr0 on
  • edited July 2011
    got an external floppy attached?
    If so stick your z80 snaps on a 720k dos floppy, then copy them to the hard disk using garry's MSDOS utility
    alternatively create a 720k +3DOS format floppy and transfer the files onto that on the PC with an appropriate utility. Then you can just copy b: to c: on the +3
  • edited July 2011
    Thanks Guesser,
    would there be any other ways?
    perhaps under emulation?
  • edited July 2011
    Hi
    Zetr0 wrote: »
    Thanks for reading.
    There isn't any simple way to do it :-(
    I use a CF 8bits version in my spectrum +2E and I always wish someone make this application (I don't have this knowlegde).
    The only way I found is:
    Make z80 files with a emulator.
    Use CPCFS to pass files to a dsk http://hardware.speccy.org/temp/cpcfs.html
    Use eightone emulator to pass dsk to real CF http://hardware.speccy.org/temp/eightone.html
    Bye
    Jos? Leandro
  • edited July 2011
    Could Gasman's recently-updated hdfmonkey be used for this?
  • edited July 2011
    Zetr0 wrote: »
    Thanks Guesser,
    simply use a +3dos disk image in place of the +3dos floppy in my second suggestion.
  • edited July 2011
    zxbruno wrote: »
    I don't think so, as I understand the +3e uses its own filesystem format based on +3 DOS, whereas hdfmonkey only works with FAT. I could be wrong though...
  • edited July 2011
    gasman wrote: »
    Yes, the +3e uses +3DOS partitions on an IDEDOS partitioned hard disk. It's rather a shame that the 3E utility can't work with half sector disks. I don't know if it's still being developed, but if not the source is available so perhaps someone could add support.
  • edited July 2011
    What about this?
    Update - 27 July 2009
    An exciting new utility is currently under development by Miguel Angel Rodriguez Jodar. Named 3e, this is a command-line utility allowing you to copy files between your PC (Windows, Mac or Unix) and a hard disk/card or HDF file formatted for use on the ZX Spectrum +3e. Although this is currently only alpha software, and has several restrictions, it is already an extremely useful utility. You can find the latest version at http://www.zxprojects.com/images/stories/3e_card_manager/3e.zip
    Miguel Angel is McLeodIdeaFix. Miguel, any chance your utility could be used for what they need?
  • edited July 2011
    zxbruno wrote: »
    What about this?
    Aha, it's McLeod's utility. Now I know who to pester :)
  • edited July 2011
    I think I better disappear for a couple hours...
    /me runs
  • edited July 2011
    zxbruno wrote: »
    /me runs
    rofl :lol:
  • edited July 2011
    About the "3e" utility. Halved sized sector devices is WIP. I got a binary image of a Compact Flash device formatted and used this way (I only have +3e with DivIDE and ZXMMC). If such update hasn't been already performed is only because halved sized sectors require a rewrite of the low-level functions that perform sector read/writes, so the accesses are "sector size independent". Well, and because I'm too lazy :D
  • edited July 2011
    I feel your pain, I have the opposite problem, all my code is only tested on half sectors as I have no 16 bit device :D
    Oh, while I remember, there's another "feature request" from someone on irc. That is IDEDOS system partitions starting on Head 1 rather than Head 0. i.e. disks with an IBM PC MBR on C0,H0,S1
  • edited July 2011
    guesser wrote: »
    Ok! Yes, you're right. The so called DOS compatibility mode that Garry introduced so that you can share a CF/SD with DOS partitions and IDEDOS volumes...
  • edited July 2011
    Yup, he had to hack a fixed offset into the code to get at his partitions which was a bit clumsy :)
