Android on your PC
edited September 2011 in Chit chat
http://WWW.Android-x86.org
Anyone tried it? Seems to support my EEE PC, with the exception of touchscreen support, although I assume the mouse you can use instead.
Going to burn a live CD tonight, and if all goes well I'm going to repartition my drive and install it.
Post edited by Hercules on
  • edited September 2011
    I might give that a go. I've only been using Android for 3 days since I got my new tablet and I'm really liking the Android OS. It's super-fast, I can be browsing (as long as I put the tablet into Deep Sleep) within 5 seconds of turning on!
    I downloaded a Speccy emulator from the Market (Marvin?) and it's pretty good. Love the way it pulls files from WOS FTP!
    Yes, it works fine as long as you have supported hardware. Had it on my Eee pc for months.
    To be honest, android doesn't feel very nice to use without a touch screen and the lack of marketplace app means you have to hunt around for apks to install. It's an impressive achievement and a fun thing to muck about with though.
    It won't run any of the current crop of Android speccy emulators though, as they all have native ARM code in their Z80 cores. I was thinking of knocking together a dalvik-based emulator myself but haven't quite got around to it yet.
    ccowley wrote: »
    Burnt the ISO onto a CD this evening. I'm really impressed!
    ccowley wrote: »
    Hopefully the Android Market app gets converted soon over to it... I remember a similar problem on the zt180 android tablet - the early firmwares never had the Android market added, you had to add it yourself. That was until they included it in a future firmware update. Hopefully the same thing will occur with Android x86...
    ccowley wrote: »
    That's a shame; their a little task for your next project then... I'll be happy to become a beta tester if you need one :)
    I've just been looking at a 2nd hand net book that's pre-loaded (dual booting) with Windows 7 and an Android OS. I'm in two minds about picking it up or not. A quick look shows that it may have a touch screen too.
