Media sharing
We're having trouble doing media sharing between two PCs. This is what we've got connected directly to our router:
Wired (network cables):
2 PCs
Wireless:
Xbox360
Wii
HP Touchpad Tablet thingy (running WebOS)
2 mobile phones
My PC and the 360 can see each other fine. Siouxsie's PC can see the 360 fine aswell. The problem is that the PCs can't see each other at all.
How can I get WMP to share folders between both PCs? Both have Media Sharing turned on in WMP on both machines but nothing is coming up in the connected devices other than the Xbox and the HP Tablet (the tablet appears as "unknown device" but it works fine).
2 PCs
Wireless:
Xbox360
Wii
2 mobile phones
Post edited by VincentAC on
WMP uses wmiprvse.exe, wmpnetwk.exe and wmpnscfg.exe for sharing. All 3 have net access on both machines.
(you may have to enable ICMP on the network card properties if it's not already)
I've gone into the network card's properties and can't see anything for ICMP (that's the message protocol?) on either machine. Both have the same card, it's an NVIDIA nForce. I'm sure it's onboard.
--edit--
Okay, I can only see ICMP in the windows firewall settings, but neither machine has the windows firewall enabled. We're both using Sygate Personal Firewall. I can't see anything for ICMP in there.
Are the PCs on the same domain/workgroup?
In that case disable the firewall and test again :)
if you still can't ping across the network with firewalls disabled then there's something messed up in the routing.
I've restarted both machines and I can definitely share through the standard shared folders (I've added other folders with no problems at all) but I cannot ping either way.
And WMP still can't see the opposite PC.
Would it be easier just to add the shared locations to the library instead of going through the shared media route?
So sounds like there is a firewall blocking the server media player runs. I've never used that media player sharing thing, I suspect the easiest solution is just to forget it and use a network share yes :)
All the services I've seen for WMP are allowed.
Another strange thing is that the machines can't ping each other at all.
But I think I'll stop messing about with it as it's kinda working now and I don't want to screw that up :lol:
prehistoric solution which I put up with as can't be arsed with it anymore. one day used to be fine, the next the smb share couldn't be seen. times 100 infuriating...
Possibly. I have a nagging suspicion that XP can only share with passive reciever devices, so won't work if you try to share with another PC.
