New Forum "look"
2
  • edited October 2011
    I'm trying to find out where on the forums there are radio buttons?
    My test signature
    guesser wrote: »
    Something isn't working properly on a piece of software on my computer, what's wrong with it?
    You know that's not what I said, you ninny. Sure I didn't mention the radio buttons in the first post but that's because at the time I didn't know it was just a specific issue on my end.
    fogartylee wrote: »
    You mean they're missing on your end too? FINALLY!
    No radio buttons on the far right hand.
    seems the same?
    thx1138 wrote: »
    seems the same?
    Ahhh ... ok ... never fear ... the Radio Buttons are a MYTH!!!
    [noparse]I MADE IT ALL UP![/noparse] There never were any radio buttons anywhere to begin with! Mwuhahaha!
    :razz:
    hmm? So what column do you expect to be there? there's no column at all on mine.
    guesser wrote: »
    Some might only show up for mods ... but the rest of them everyone else should have.
    ZnorXman wrote: »
    No - I mean I am struggling to find out what you mean - which section of the forum?, what are you doing? where are you looking? Nothing has changed on the forum and the only radio buttons I can think of are in the polls and they are fine
    My test signature
    Search radio buttons are there
    My test signature
    fogartylee wrote: »
    For the umpteenth time ... EVERYWHERE!!!
    I am fairly sure I also posted pics a few replies back :razz:
    fogartylee wrote: »
    OK, thank you, finally a solid answer ... well, ok others kinda said the same before, hence why I thought it might just be an issue on my end but then others starting saying it was the same on their end, or that at least they didn't see any difference when they looked at the pics I posted.
    I posted the reply before I saw the pics.
    I can see your problem now. You've got no radio buttons, or check boxes. hope that helps.
    My test signature
    The answer is pretty easy here. Have you already tried a different browser and see if there are those radio things there?
    Oh, and if you looked up this problem in Google you will find many posts. :)
    ZnorXman, fantastic thread!
    ZnorXman wrote: »
    All of them, and everywhere (well, aside from that one place kinda not really)
    Radio Buttons are indeed everywhere! (I usually find at least 2-3 down the back of the sofa!)
    ZnorXman wrote: »
    The previous former one before the last one, so whatever it was that came out about a decade ago.
    Clearly Windows XP. Ubuntu wasn't even out a decade ago!
    I think the clue is in details... ZnorXman refers to Radio Buttons like a techy. Everyone fell for the don't know line! :grin:
    ZnorXman wrote: »
    Oh! Those radio buttons!
    Why didn't you say so!
    guesser wrote: »
    Crudleycrackers! They migrated, all the way over to you?!?!?!
    Stop hoarding them, and send some my way ... ( pleathe! )
    fogartylee wrote: »
    No problem, thou art forgiven! All is good, love you still.
    fogartylee wrote: »
    That's not enough ... can you hear it also?
    fogartylee wrote: »
    I know! Guesser's finally fessed up ... he's stockpiling them, like there's no tomorrow.
    fogartylee wrote: »
    , or check boxes.
    What are those? Where do I find them? Does guesser have some spare ones?
    fogartylee wrote: »
    hope that helps.
    Thank you, yes, it doesn't.
    :razz:
    Timmy wrote: »
    None in IE either ... Guesser's still got them all.
    Timmy wrote: »
    I don't need to find posts, I need to find radio buttons!!!!
    BloodBaz wrote: »
    I know, I made it just for you.
    BloodBaz wrote: »
    Can you spare a few ... please ... :razz:
    BloodBaz wrote: »
    Clearly Windows XP.
    Clearly, yes, quite right.
    BloodBaz wrote: »
    Didn't know it was still in the closet back then!
    BloodBaz wrote: »
    Should I have been wearing a pirate's suit and a parrot on me shoulder ... Yargh! And a bottle of rum!
    BloodBaz wrote: »
    What do you mean? :Confused: ... I think I fell for it, that is, that others weren't knowing what I was talking about.
    It's going to be yet another sad, sleepless night, all alone in bed without those radio buttons :sad:
    ( No change there then, eh. -Ed )
    Radio buttons are fine here. Have you tried reinstalling Chrome? (or better ditching XP entirely and going to IE9)
    AndyC wrote: »
    I'm glad you're enjoying them.
    AndyC wrote: »
    Yes, and successfully so too. Didn't do it today though, think it was maybe, like last year.
    AndyC wrote: »
    One is an operating system while the other is a web browser ... I's confuzzled.
    ZnorXman wrote: »
    I would definitely automatically discount advice to "switch to IE9" from a Microsofty. Even if it ever accidentally happens to be valid advice (which it isn't, in this circumstance, as WoS forums work just fine for me in Chrome and always have done). Gotta be wary of those hidden agendas.
    buying a new operating system to fix a browser glitch is like buying a new car to fix a cigar lighter. Sure it'll solve the problem but it's expensive and pointless.
    ccowley wrote: »
    Well my rough guess is the machine has been compromised by malware of some sort. We could go with reformat + reinstall, but to be brutally honest staying on XP is like getting rid of an STD and then going right back to the skanky brothel you caught it from.
    As to a "hidden agenda", I'm not entirely sure what you think that would be, it makes not one iota of difference to my life what browser/OS you use. Buy a Mac seems like an even more expensive move though.
    guesser wrote: »
    I agree and disagree with you there.
    I agree that it is expensive but it's definitely not pointless, as the point remains the same, i.e. to fix the issue. I think this is actually my best bet right now ... just save up some moolah and get a new 'puter.
    Problem solved.
    The mods may condemn this thread and delete it if they so choose.
    AndyC wrote: »
    Ha ha! Love that one :lol:
    AndyC wrote: »
    And the only option for fixing an otherwise perfectly functioning set of hardware is to "install IE9" which would also involve installing and (stealing or) purchasing a more recent Micorosoft operating system (and probably, in fact, purchasing a new PC too). I would go for the reinstall of XP + service packs. Couple of hours, job done, no money spent.
    Are you not a Microsoft employee or contractor then? I just assumed you were as I noticed you promote current Microsoft products shamelessly on here at every opportunity, even when better options clearly exist.
    AndyC wrote: »
    On what do you base that guess?
    Again, reinstalling XP may well make the problem go away but it doesn't fix anything, why would the same problem not appear again once he's installed the same cocktail of software, browser plugins, antivirus updates, blah blah blah.
    A better solution would be to spend a while on google and find out what's wrong with the configuration and put it right. As Timmy said, there are loads of sites about missing radio buttons in chrome.
    AndyC wrote: »
    Who even mentioned Macs?
    ZnorXman wrote: »
    No, that is pointless. When the same thing happens on your new computer you have spent all the money and the problem isn't fixed at all.
    If your PC worked last week it will work this week too, software doesn't wear out.
    ZnorXman wrote: »
    Me too....
    guesser wrote: »
    Yes it does... Well, mine does, :P
