Can Anyone Recommend a Decent Cheap Freeview HD Recorder
Ive been meaning to buy one for my Dad as he is still using VHS which did the job but now that the analogue TV signal has been switched off he cant tape one channel and watch the other at the same time.
Im after a Twin Receiver with 120gb HD and series link
Id prefer to spend less than ?80
Can anyone recommend a decent enough one?
Post edited by festershinetop on
If anyone has one...are they worth getting?
http://direct.tesco.com/q/N.2000833/Nr.99.aspx
both sites have reviews
http://www.ebuyer.com/store/Visual/cat/Digital-and-Satellite-TV
is another also.
I'd avoid the sagem ones as I got stitched up by them using the wrong tech in the past (they used setpal.. for a box I bought.. had to buy a new one)
