Looking for an old thread
Is it possible to search the Chit Chat forum?
I'm looking for the PS2 thread from a few months back but to no avail.
Post edited by Rebelstar without a cause on
  • edited November 2011
    Should be able to find it, did you post in it ? Might be easier to go back through your old posts ?
    Did a search for PS2 and seemed to be a few threads but unsure what one you're after.
    Is it the "PS2 Megathread" one? I can't seem to find it either!
    Tis here...
    http://www.worldofspectrum.org/forums/showthread.php?t=33458
    Weird, using a normal search and typing in PS2 i couldnt find it at all. Searched through Greencards history and found it months ago when he had obviously replied in it, think at the time people were being 'silly' and creating 'megathreads' for every console there was ! Thought it might had been deleted but obviously not
    It's easy Rebelstar - just start a new one, sit back and wait. Alessandro will soon find it for you
  • It's easy Rebelstar - just start a new one, sit back and wait. Alessandro will soon find it for you
    :D yeah did think of doing that!
  • psj3809 wrote: »
    Tis here...
    That's the one. Thanks :-)
    Chit Chat doesn't show up in search results, IIRC, and Google doesn't index WoS Forums so you won't find it that way either.
    AndyC wrote: »
    It shows up for me... :)
    For future reference, you should tag all the threads you create.
    They can then be easily found via a tag search (Search|Tag Search).
    Eg, searching for "skyrim" via a normal search returns two unrelated threads for me, but the correct thread is returned when doing a tag search on "skyrim".
    GreenCard wrote: »
    Threads in Chit Chat that were created before the change (i.e. before not being able to search C-C) are included. So you might be getting old threads (I've fallen for this before and made a loud complaint to Mr Wos-Himself and he set me straight :razz: )
    Daren wrote: »
