Operation Caretaker
From this review it seems there are more than one version of Operation Caretaker
I think the one in the archive is the early version as reviewed here
and the version I have is a newer version as reviewed here
My copy has more detailed instructions.
Also a different inlay.
Post edited by Hairy on
It can be downloaded here.
At a glance it looks the same, hopefully someone can compare the two and come to a conclusion.
I've compared them in Tapir and the only difference appears to be the checksum byte
on the main code header. So the actual data is the same.
However, when we have different covers, we usually try and store both TZXs.
I'm not sure which cover version the existing TZX was made from, so the only way
would be to redump both to be sure.
Just puchased the one with the red cross on the cover in a bundle, so when it arrives I'll make a TZX. Will take over a week to arrive though as seller only posts Saturday. Link
Might have another MIA too in this lot
