faulty
edited December 2011 in Hardware
i have a zx48 that will not tune in it allways seems to be just out of tune what could cause this fault also half of the keyboard doesnot work there has been a repaire done on a diode and it looks like its shorted i woud post a pic but cant work it out lol
Post edited by ozzyzx on
  • edited December 2011
    well the little guy is dead :sad:
    If it produced something of a display and you could see that some of the keys functioned, then there probably isn't anything too seriously wrong with it and it almost certainly can be repaired. It could be rather time consuming though (see the thread about the Issue 2 Spectrum I've been working on - it is working now, though I'm still trying to work out why one particular problem happened.)
    The screw in the tuner has shatterd the membrain only works on half a side and a dioed has been replace but left to long so when the top was put in it bent over and connected the 2 diods next to it aswell so thats shorted out so its a little bit beyone my skills at this moment in time
    ozzyzx wrote: »
    someone's used a metal screwdriver on it...
    Besides most people seem to bypass the modulator and use composite video anyway :)
    ozzyzx wrote: »
    rwap sells reproduction menbranes
    ozzyzx wrote: »
    It is fixable though :)
    how do i go about fixing the video output in it then is it a complecated thing
    ozzyzx wrote: »
    Have a look here:
    http://womblesretrorepairshack.blogspot.com/2008/11/zx-spectrum-composite-video-mod.html
    cool thanks
    how can i put a pic on here i will post the board in its state now
    hmm so thats all u do disconnect those 3 things and stick 1 wire in its place
    ozzyzx wrote: »
    cool thanks
    you will have to find somewhere to put the photograph online, and then post the url here in img tags.
    e.g.
    [noparse]image.jpg[/noparse]
    this is the repair that was done before i got my grubby paws on it
    as u can see who ever did this repair left that end one to long so when the lid was put down it connected its self to the 2 next to it and gave it a nice black mark on the back
    ozzyzx wrote: »
    cool thanks
    Store the picture somewhere online, get the URL to its location, then create a post here with this:
    [noparse]URL-to-the-picture[/noparse]
    Here is an example:
    The URL to the picture in the top left of this page (black square that says "FORUMS World of Spectrum") is [noparse]http://www.worldofspectrum.org/forums/images/custom/forums.gif[/noparse] so I just copy that URL and plop it between the IMG tags, like so [noparse]forums.gif[/noparse]
    And when I submit my post it comes out like a regular picture:
    ( PS "But how are you able to use the IMG tags in this example without it being interpreted as an IMG tag???" I hear you cry ... well, I am able to use the [noparse][img][/img][/noparse] tags without the forum software parsing it by putting [noparse][noparse][/noparse][/noparse] before and after the IMG tags for demonstration purposes (and so can you))
    EDIT: HAHA, you beat me to it by a minute ... good job! And I see guesser helped out too.
    was being blond and looking for a dam paperclip soon as he said u need a website the brain woke up n pushed the blond to one side for a moment
    ozzyzx wrote: »
    Is that R55? it should be a 56 ohm resistor as far as I can tell...
    If so it looks like the -5v supply has probably been shorted out and if so that will have caused a cascade of problems for you :(
    I would be possibly expecting to see TR4 being overloaded and almost certainly ram being damaged if the -5v supply disappeared :(
    it ether says R55 or R85 as it has a pain line going through the middle it turns on but the screen is like its out of tune so im going to try that mod but cant seem to get my head round it the long chip on the board has been lifted out and put back wrong so the pins were bent thats been sorted no damage there
    so your opinion is it a scraper or something that can be saved
    ozzyzx wrote: »
    So your opinion is it a scraper or something that can be saved
    If the ULA works then the spectrum can be saved basically. Whether it's economical to do so is another matter but it doesn't look to me like your board is damaged at least not in the bits you photographed. All the components can be replaced except the ULA
    What issue is the board? The photo doesn't quite match either of the two I've got open on my workbench.
    It probably can be repaired, but it sounds as if there has been quite a lot of damage. Don't scrap it, in the worst case it can provide spare parts to help repair another.
    im looking at this mod if it works and i get a clear picture i will have a better clue how badly cooked it is but far as i can see its just disconect evreything and put a single wire in its palce is it that simple
    another thing is only half of the keys work dont know if thats down tot he board or the ribbon cables
    did the mod and the screen is stable but i end up with this on the screen now
    ozzyzx wrote: »
    ...another thing is only half of the keys work dont know if thats down tot he board or the ribbon cables
    And here is the answer you're looking for: [noparse]http://www.rwapsoftware.co.uk/[/noparse]
    How are you able to tell that some of the keys work? It looks as if that Spectrum doesn't work well enough for you to be able to tell.
    The ULA is generating a video signal, so that component at least isn't completely dead. I'd say there's a decent chance it can be fully repaired.
    before u could hear a click when u pressed some of the buttons
    what do you thinks gone on this thing
    ozzyzx wrote: »
    Did you even read comments no 20 or 5 ???
    yeah read those but those probs are done i now have it on im just wondering why the graphic output is like this now before it was white with letters on it but the screen was to fuzzy to see now its clear i got the black
    If it was making a clicking noise when you pressed a key, then at least all the major components were functioning. I assume this does not happen now. What did you do/happened to it to damage it further?
    If I were repairing it, I'd start by checking whether the power supply circuitry is working and whether the various voltages it produces are present where they should be. If not, it's likely some or all of the lower RAM chips have failed, which can produce a display like the one you posted, though so can other faults too.
    connected the keyboard cut back the ribbon cable and when i powers it on i heard a click from the speaker from some buttons but not others but now i have done the mod the pic is perfect but just jibberish was just trying to find out if this is a fault somewhere elce or one related to the origonal one like the video fault someone gave me a link i used 2 blobs of solder fixed there could have been a similar fix to this well i was hoping
    i have done nothing but the previous mod if you are saying it could be ram puts me back to the original fault with the blown capacitors
    I think it needs to be examined by someone more familiar with working on electronic circuits.
    You hadn't said anything about failed capacitors before. Did you replace them (and possibly try to determine why they had failed)? I wouldn't have even switched it on if not as it could possibly cause further damage.
    i have loads of information on this now i have narrowed the problem down to a few things and i now need to do a little pricing up and decide if this is for the spairs bin or worth repairing
    Thanks for all your paitance and help
    ozzyzx wrote: »
    jibberish was just trying to find out.
    I hope Mr. Jibberish succeeds. Wish I had a butler like that.
