microdrive rubber roller
edited January 2012 in Hardware
where can one find replacement rubber roller?
is alcohol really ok for cleaning it?
thanks.
edit: I've searched a bit, and "Platenclene" seems to be good for cleaning.
IPA should be avoided.
Post edited by orange on
  • edited January 2012
    I've found this one:
    http://www.mcmelectronics.com/product/DISTRIBUTED-BY-MCM-AP-9-/42-3250
    but not sure if it fits. anyone got precise measurements?
    9mm sounds big, been a while since I had one open but it sure seemed smaller than that in diameter. Let us know if you try one and it works though.
    I'm really really sure alchohol is fine for cleaning it.
    RobeeeJay wrote: »
    ok, I'll give it a go. IPA?
    but at one point, I'll have to replace it. so better have a spare.
    comparing to unused one (well half-used) it seems the roller lost a bit of radius.
    edit: I made some measurements, approx: 6mmX5mmX1mm (where 5mm is height)
    My poison of choice for cleaning heads/pinch wheels has always been:
    http://en.wikipedia.org/wiki/Denatured_alcohol
    Finding a replacement wheel may prove a bit hit and miss. You really need exact measurements of the original un-worn one. Is there a Microdrive service manual anywhere that could have the dimensions in?
    Greene King will definitely make it sticky and ruin the tape :razz:
    orange wrote: »
    I've used IPA for several years on them without any issues.
    Yes remember the roller can be turned upside down and used as a 'new' roller
    RobeeeJay wrote: »
    Yes - it is here on WoS. Unfortunately the only description of the rollers is that they are "smooth wall" and made by R E components (maybe the OCR got it wrong and they meant RS Components?). I have read the booklet and can't see any measurements of the rollers. :-(
    From my experience Sinclair modified the microdrives during their manufacturing lifetime, so the later models are much better (and quieter) than the first issue.
