Little help with the Spectrum Disk Preservation Project Page
I dont think I understand this page very well, as Im checking the games and some of them appear already as preserved in dsk. file in the database.
Could it be that the general update of that page was in 02/08/2008? and therefore all the games added to WoS since then have not been deleted from that list?
http://www.worldofspectrum.org/sdp/games.html
And on the other hand, that list refers to the games that have a known +3 version, right?
Thanks!
Thanks!
Post edited by Ivanzx on
<a href="http://rincondelspectrum.blogspot.de/" target="_blank" rel="nofollow">http://rincondelspectrum.blogspot.de/</a>
http://www.worldofspectrum.org/sdp/opus.html
It says in the page that Gryzor is from 1986, when it is actually from 1987.
As such, it may be "a bit" behind with updates.
The dates seem to differ per section right now.
-Super Sapiens
-Poli Diaz
-Mambo
Indeed the SDP section is updated by myself ;-). Since Dreamweaver didn't appear to show me the files in the WoS account I had to do the pages and then upload with Filezilla.
Hmm, seems it allows me to put a file, but doesn't show the remote site files. This happened when WoS moved servers, I have no idea why Dreamweaver doesn't show them ?
I've recently been updating some to indicate a number of Outlet +3 dump will be available in the next Vault Update / WoS Sync, colouring them in blue.
They'll be all sorts of inaccuracies on there.
When I update a page, I update the date at the bottom to indicate a change.
I also need to remove the references to CPDRead, as my preferred method to make a EDSK image is to use SamDisk... however before release I convert the images to legacy mode so multiple stored sectors aren't kept. I still keep the SamDisk dumps, but in most cases doesn't need the multi sector reads.
I'll have another look at the pages and try to tidy them up and refresh them.
These titles are quite possibly non-UK releases. I generally only know/deal with UK +3 disks, SPA2 will handle Spanish disks. Though I'm not sure about others, I've never really had many to deal with.
I think SDP generation was on Martijn's massive todo list, but it's way down the bottom somewhere ;-). So for now I manually update it as and when.
Yep, you are right, those 3 games I mentioned were Spanish :)
Thanks for all your work, its really appreciated ;)
