Horizons
Horizons contains several files that are identified incorrectly:
- File "Horizons(Micropress2).tzx.zip" is incorrectly identified as "English", it's actually Dutch.
- File "Horizons(RebitComputer).tzx.zip" is incorrectly identified as "English", it's actually Italian.
- File "Horizons(Arco-Iris)(Microdigital).tzx.zip" is incorrectly identified as "Portuguese", it's actually the Spanish TK95 variant.
- Arco-Iris TK90X Portuguese (in Brazil)
- Arco-Iris TK95 Portuguese (in Brazil)
- Arco-Iris TK90X Spanish (in Argentina, Chile, Uruguay, Ecuador)
- Arco-Iris TK95 Spanish (in Argentina, Chile, Uruguay, Ecuador)
Ops, the 3rd file I mentioned is still wrong!
File "Horizons(Arco-Iris)(Microdigital).tzx.zip" is incorrect, it should be "Spanish".
File "Horizons(Arco-Iris)(Microdigital).tap.zip" is correct, it should remain as "Portuguese".
I suppose there's some confusion because these 2 files have the same filename (only different extension), although their contents are different (not just the format). Because of this, I suggest renaming them as follows:
Including "TK95" in the filename is relevant since luckily in the future someone will also recover "Horizons(Arco-Iris)(Microdigital)(TK90X-Spanish)" and "Horizons(Arco-Iris)(Microdigital)(TK90X-Portuguese)" that also have different contents.
This was done to take care of the many corrections provided; I only have to take care of the database fields and the files will get renamed automatically at the next update. :-)
That said, I could do something: rename the re-release title to "Arco-Iris [system]" (e.g. "Arco-Iris TK95").
I then checked the archive of uploads that have not been used yet, and found the (.tap) Portuguese TK90X version, provided by Marcelo Vianna in 2006, and added that as well.
... Well, almost everything. Inside the new package "Horizons(Arco-IrisTK90X)(Microdigital).tap.zip" you just added, the sides are reversed. I mean, this package includes file "ARCO side a.TAP" that contains side B of the original tape, and "ARCO side B.TAP" that contains side A of the original tape.
