Would there be interest in new powered dual-floppy setups?
I can make some of these dual diskdrive sets:
Specs:
- 2x 1.44MB HD floppydrives (modified to DS0 and DS1)
- Compatible with DD floppy disks or HD floppies with the HD-hole covered
- Integrated (modified) floppycable
- External 5V wall socket power supply included
This set is compatible with the PlusD, Disciple and other disk systems that can handle 80 track DD drives.
Price: €50 + p&p.
Any interest?
Specs:
Price: €50 + p&p.
Any interest?
Post edited by bverstee on
Yupp. That would do the trick.
Snap!
http://mdfs.net/Info/Comp/BBC/pics/Drives/Twin35.jpg
If someone can provide me a schematic...
But even with a schematic: it seems this interface uses a WD1793 chip that is very obsolete.
I can however find some WD1772 chips (pricy though: about 15 euro each).
I might want to make some PlusD interfaces, as cheap as possible.
I would leave out the parallel port, and make the pcb as small as possible.
This way I might be able to produce a PlusD set with dual floppydrive for about 100 euro.
Could that be interesting?
Ah a bit too spicy for me at ?50 but they do look loverly :cool:
I am ordering black floppycables, so the set will be totally black ;)
A European power supply is included with the price of 50? (ex postage).
If needed I can order US or UK power supplies to include.
http://cygnus.speccy.cz/popis_trdos-schema.php
Only Beta gives access to TR-DOS files.
Maybe it is possible to replace WD with ATMega and SD/CF card. My friend told me they are to slow to handle Z80 I/O, but I don't think so.
From his video description that should be DISCiPLE. Although looking good coupled with 128k, I find it too bulky to go with Rubber model. Still a great work you've done. I especially like the long data cable. Much better than those short micro drive / Didaktik D40 etc. cords.
If you find an easy* way for +2A and +3 users to emulate the PlusD and Disciple you could have a much larger target audience. Those computers wouldn't require any interface.
* there's already a way but it isn't easy.
I wonder how, because the DivIDE is a lot easier to use, isn't it?
I am investigating the possibility to build PlusD or another interface, e.g. Betadisc. But I have no good schematic of the Betadisc interface, and never had one, so it's a lot harder.
The PlusD can be made quite easily I think.
The hardest part is to obtain WD1772 chips.
And I would make a PlusD 'light' version that leaves out e.g. the parallel port and maybe more, to save costs.
They're not on the same level at all.
Most of complicated diskette programs don't want work from tape - even the emulated one.
Because of maaaaaaany various reasons.
Possible track-loading, TR-DOS versions only, playing AY while loading (which is impossible on tape or emulated tape - which divIDE with FatWare is).
And so on.
Not to mention loads of good utilities, simple and comfortable saving ability... Etc.
Beta-disc is very simple interface as you can see on pictures I sent.
Just WD is needed.
But I would try with controller - any links known to such solution ?
Small board that you can put in place of 765/wd17x... Nice.:razz:
We start to sell them probably next week.
Regards
Thomas
I would be interested on buying a plusD. Can you estimate the cost?
I think so, otherwise it would be easy to convert TR-DOS files to TAP.
DivIDE seems to have most (all?) needed traps, but 8K rom size is also limit.
I think kind of dynamic loading as in EXSDOS is needed.
Beta has just few registers on Z80 side, there should be possible to place them in ATmega, but I have never seen solution like that.
I'm too busy with other things for the foreseeable future, but there are VHDL WD implementations out there that could be used as a starting point.
