PlusD 'plus' ideas
I am thinking of producing PlusD interfaces.
But I want:
- to leave out the parallel port - is it needed nowadays?
- to include a joystick port
And I want to make it as cheap as possible, so I will try to keep the pcb as small as possible.
Any other ideas? Please keep the above in mind.
But I want:
Post edited by bverstee on
Reset button if not included already, for rubber keyed machines will be useful.
Switchable DOS perhaps (either GDOS or Uni-Dos)?
Asking about obsolete printer port for interface for obsolete Disc drives. I ROFLed!
If you want to leave Parallel port out, do so. I would make my clone with 25 pin Sub-D parallel port because I still need it (my parallel port of +D does not work anymore).
Wanna sell it? Then I woulb buy one, even without WD1772 Chip (still have three of them spare), but only if there is a parallel port. Surely you can add a Kempston joystick port. It would not use much space if you use SMD parts.
That's a thought. :)
Ingo.
I'm not making the PlusD as someone else is already doing a redesign.
But if I would have, I would have thought of leaving the parallel port out and adding a joystick interface instead.
But indeed, why not keep the parallel port, it's just that I didn't think anyone would use it today.
