Football Director - Staying on easy level
Using Spin load the tzx file from the WOS archive.
Wait for the game to load fully and the main menu appears.
From the emulator's tools menu select poke memory.
Enter the address as 65251 and the value as 162
and click add.
Now enter address 65252 and value 18. Click add and then finish
You can now break into the program using shift and space.
Add the following to the start of line 6:
Let jt=-1: Let ab=-1: Let ra=3
Type Goto 6
The game will now stay on easy level!
You can check this by changing the level to hard then return to the main menu. Now check the level again and it will be back to normal.
and click add.
Type Goto 6
Post edited by Rebelstar without a cause on
Maybe you should forward this tip to the next Chelsea manager :p
