Strange problem with +2A tape drive
I recently bought a +2A. I load software using an cassette adapter connected to a laptop. The first week or so it worked beautifully, load menu, press play on built in tape drive, then play in K7ZX on the laptop and off we go.
However, since yesterday the built in tape drive has gone bananas. It keeps stopping by itself!
That is, I press play, loading starts, then after a few seconds I hear a "CLICK" and the play button pops back up and the loading stops.
I managed get a load to finish successfully by forcibly holding the play button down the entire time, but I could hear the clicking sound of it TRYING to stop the entire time so I felt as I was abusing my poor Spectrum, and I'm a bit scared that I'll hurt some hardware.
However, I need to finish my demo in time for Forever party later this week, so I need to load stuff, and soon!
Any ideas what's going on and how I could solve it?
Post edited by Sdw on
http://www.worldofspectrum.org/forums/showthread.php?t=34633
Please note that although the thread was last updated in June 2011, I kept loading software via the cassette adapter the way described there in the following months and so far it has proven to be a reliable and safe method. Traditional cassette loading has not been affected in any way.
That said, the cassette mechanism is probably filled with dust and needs a thorough cleaning and a (very small) bit of machine grease to be restored in its functionality. However this means you must open the +2A case and be sure to know where to put your hands on :) Some useful advice can be found here:
http://www.dataserve-retro.co.uk/contents/en-uk/d54.html
I did try that, but either my output or the cassette adapter is crap, because without pressing play, I didn't get any signal at all.
However, I came up with the following solution:
1) Insert tape out of the slot
2) Make sure the "play" button is pressed enough to make contact, but not enough to start spinning the motor
3) Since step 2 is kind of exhausting for the finger after a while, I found out that three layers of cardboard placed strategically held the play button pressed juuuuust enough!
Gotta love old computers!
I do wonder though, if having the tape head in constant contact with the tape adapter (even when turned off) could have any ill effects? Magnetic or otherwise?
The main problem I found was that if you keep the play button pressed, the capstan and pinch roller are in constant contact, and later it makes a permanent indentation on the pinch roller. The result is a wobbly sound, and pretty much screws up loading from real tape.
