netbook
I'm thinking about buying a cheap netbook. Normally I use a desktop computer, but sometimes a cheap laptop I take around to places. My last one has just packed it in so I am looking around for a new one now.I'm looking for a light, quiet, cool one that runs Linux and has an OK battery life... There are so many models that I don't know which to go for. Also I have only a very small amount of money.
Does anyone have/use/recommend one?
Post edited by wilsonsamm on
Is a tablet any good ?? there are plenty of good android tablets about.
My current favorite "netbook" is the Acer Aspire AO722-0825. It's something in between a netbook and a laptop. No optical drive but with its 4GB of ram (standard, upgradeable to 8GB) it's a much better machine. Still small (11.6" screen size), battery life isn't as good as that Samsung, but a good amount of ram is always good.
Half the price? The Samsung ones should set you back about ?200 and I'd be very surprised if you can get the HP Mini 110 for half that; a quick peek on Google shopping suggested that prices are similar but if you can get one for ?100 jump at it.
So far as I can tell, I think the battery life on the Samsung is a bit better, but other than that they're of similar spec; most netbooks are, as there's not a huge choice of CPU and chipsets.
It's fast enough for what I use it for, which is browsing, playing AVIs and emulation.
Final tip: You can install 'jupiter' under linux, which allows you to control the CPU performance modes, turn off bluetooth, etc which help to give you a little extra juice out of the battery when out and about. Recommend you install it on your shiny new netbook when you get it :)
