SJS2 joystick and spectrum +2 (grey)
Should the SJS2 joystick work with the +2? i assume in game you select 'Sinclair joystick'?
just tried Donkey Kong (ocean) with the above scenario and moving the joystick left worked, jump worked but right didn't.
Post edited by jackleather on
When connected and moved, you should see some cyphers appear on the screen, since Sinclair joystick map to the keyboard (so to speak).
Port 1 returns:
6=left
7=right
8=down
9=up
0=fire
Port 2 returns:
1=left
2=right
3=down
4=up
5=fire
If you do not see some of these cyphers appear when you move your joystick and/or press fire, then it's most probably broken.
