psytron problems
hello chaps and chapesses. Recently downloaded zx-32 and spectaculator. Downloaded Psytron. Played it (good times!) at the end of the first go on the first level though, Im 99.99% certain that there are errors with the game :/
Original game, finish level then you have left aligned
1: __ __ __ __ 58%
in the tap and tzx versions I downloaded from WOS, when level 1 is finished there is some garbage in the start of the text area and the right hand side of the scoring goes into teh droid screen (bottom right) like this
?? S? ...................... 1: __ __
....................................... __ 49 57
like that. Can anyone shed any light on what im doing wrong please?
Chad
edit: got a mate to check - same thing. the formatting is all messed up over about 3 lines - weirdness cause the rest of the lines are fine...heeelp?
1: __ __ __ __ 58%
Chad
Post edited by chad0x on
Now the question is, which emulator (free) should I be using? thanks for your help :D
