What's this?
2»
  • edited July 2012
    Ralf wrote: »
    Good job, Saltor! It looks like you saved another missing program from extinction.
    Don't forget to upload the .tzx files to WOS when you're ready with them :)
    What is the exact procedure?
    Cultural association in south Italy
    www.apuliaretrocomputing.it
    Personal site
    www.sinclairitaly.wordpress.com
  • edited July 2012
    Create your .tzx files. If there are some programs on a single cassette put them all into a single .tzx.
    Then you go here:
    http://www.worldofspectrum.org/upload.html
    2) You fill the description (not necessary but nice and helpful)
    3) You attach your files (may be all zipped into a single file ) and press "send" :)
    Alternatively you may use FTP if your are familiar with it. It's explained at the linked page.
    Ask if you have any more questions. Good luck :)
  • edited August 2012
    Done a couple of weeks ago.
    But only inlays have been published on WOS at the moment.
    Personal site
    That's how WOS works :)
    When you upload inlays, instructions, new current year software and some other stuff they will appear usually in a day or two.
    When you upload old, historical software it will appear online through database updates (like this: http://www.worldofspectrum.org/archive.new.120720.html ) which are not so often, 2-3 times a year or so.
    So don't worry about your upload, it's not lost and will eventually appear :)
    Ralf wrote: »
    Thank you!:smile:
    Personal site
