name the game....
edited August 2012 in Games
edit: SOLVED: Rally Bug.
you're a ball, object of each level is to go from l-r and get to the end of the screen, jumping over stuff. if you fall down cracks in the floor you die. I think the screen keeps moving so if you're too slow you get caught + lose life, not 100% sure about that bit
pretty sure it's a recent(ish) one, maybe by someone off here?
Post edited by def chris on
