16k Issue 2 board and DivIDE load errors
I today got an Issue 2 16k board (thank you PMSR) that i added the logic and ram on to get a 48k machine. However, I am unable to load software from DivIDE. I get a lot of R loading errors, and sometimes the machine wants to reset randomly. Any suggestions?
Post edited by Johan1973 on
Update, specifically keys 6 to 0 is not working.
/Pedro
Might he problem with loading from audio source through EAR and loading .tap files from DivIDE be related?
Anyway, thank you for the board Pedro. It is beautiful. Much better condition than the Issue 2 I had picked up and was working on :)
Did you check the 7805 output voltage? is it really 5.0 +/-0.1V? Is there an undesired ripple? If possible change the 7805 against a new/different one. Is the 12V line ok? is it about 11 ... 13V? Are the electrolytic capacitors cool? if there is a warm or deformed electrolytic capacitor change it.
Ingo.
www.rwapsoftware.co.uk
www.sellmyretro.com
I have tried to load 16k .tap files, does not matter, it immediately resets when trying to load a .tap file.
YAHOOOO!!!!
Thank you Pedro,RWAP and all others who replied to this thread.
Thank you again Pedro for an excellent quality board.
/Pedro
The mentioned paper/aluminum "shield". I think the first ZX I ever owned had something like this, but I have not seen it again until now.
Machine in its case with new keyboard membrane and DivIDE up and running :)
Thank you. But was easy to work with such a prime example as PMSR sent me :) It was in perfect condition. All I did was changing cpu to a Zilog Z80, socket the ROM, put 4164's as low ram (cutting -5V and +12V track and route +5V to where +12V used to connect on lower ram). Put logic chips and 4164s as high ram. Add a buffer transistor to the beeper to increase volume.
I love my DivIDE. Before it I loaded software from PC sound card. Which was quite a pain compared to how I do it now :)
I have made all the ICs socketed, to make it easy to test chips and do tests. This machine will keep its 4116 memory modules and be kept in original configuration to have a reference machine for any future projects.
This circuit might be far from ideal. But it provides more than enough volume from the buzzer without causing distortion (at least with the speaker I use).
This. Has anyone else seen it? Was it factory installed?
/Pedro
/Pedro
Some other countries may have had similar requirements in their laws that made such a screen necessary.
