Games on Windows7 with DOSBOX
What's the best way to run these? I've now got a reason to use DOS-Box (Star Wars: Rebel Assault)... any ideas please?
(It's easier to ask my friends on here as they are prepared to give clear instructions)
Thanks.
Thanks.
Post edited by zeropolis79 on
errm there is a setup / run file on the cd prolly see how that works. think that just setups the environment vars.. and calls the cd to start (a batch file IRC)
a LOT of it will run off the drive if I remember right. so you can always use a virtual image perhaps
If you wanna simplify things a little bit, I recommend a frontend like D.O.G. I use that myself and it makes the whole task of configuring DOSBox much easier for each game.
Thanks for the comments.
