Amstrad or Spectrum?
Another silly question...
I just got some CF-2 disks and tried them in a Spectrum +3. I can CAT the disk, but none of the programs appear to load correctly, so I'm wondering if they are Amstrad files, or perhaps some other odd format requiring a special loader or such. (
Thanks!
Thanks!
Post edited by Pstrinic on
On the other way, they could contain just data, not BASIC or CODE files. An Amstrad disk is a merely a data disk for the +3.
Sounds about right (though of course +3 and CPC could have files with .bin and .doc extensions too if they wanted). The end of file error is pretty much what you get if you try to load a CPC file on a Spectrum.
There were three 'original' formats, the two of which you were most likely to encounter were System and Data format (Vortex being the third and rather obscure).
+3DOS supports all of those and some PCW only formats as well IIRC, which is why you can see the files, even if you can't actually use them.
