Tape loading from PC
edited October 2012 in Hardware
So, I found that I had been using the wrong audio jack socket on my 48k for tape loading (my spectrum is in a third party case, so there are not labels). This may be why I am unable to load some programs.
My setup is as follows: My laptop running unix with mplayer playing a wav file. The wav was converted from tzx using tape2wav from the fuse emulator package. I'm using a mono audio jack from my laptop to the right audio jack (as you are facing the keyboard front on as though you were typing). I believe this is the "ear" socket.
The problem is, i don't think my laptop is loud enough, even though my laptop is at full volume. I even tried using mplayer's software volume control at 1000% (its probably clipping my then anyway).
I found this similar issues, but it seems it was unsolved:
http://www.worldofspectrum.org/forums/showthread.php?t=40882
Any tips? :confused:
Post edited by vext01 on
  • edited October 2012
    Audio input to the Spectrum should be through the connector nearest the television RF modulator. Use a cable that has a mono jack plug at one end (the Spectrum end) and a stereo plug at the other; at this end, connect the cable core to just one of the signal contacts (I recommend the tip). The cable screen should, of course, be connected in the usual way at both ends.
    Some PC audio outputs can't produce a signal quite strong enough for a Spectrum. A small amplifier of the sort intended for driving headphones or a set of amplified computer speakers with a headphone output may prove helpful. If the PC is running Windows, check the audio driver settings. Some have an extra 'boost' setting and if it has equalisation controls, set all the bands to maximum.
    Finally, if you are generating audio from an archive file (i.e. a TZX or similar file), you might try a different utility to do so. Quite a long time ago, I remember noticing that the tape2wav tool that comes with the FUSE emulator produced (to my ears) tones that were slightly off from those generated by a Spectrum and it wasn't easy to get a Spectrum to load from these files. Perhaps there are other such utilities that aren't quite perfect. I've always found playtzx to work well.
    I've never managed to load programs via the sound card. Not only is the level of the audio signal a problem, but the noise too. Listen to the soundcard output with headphones on most PCs and you'll know what I mean.
    I find the best method is to convert tzx to mp3. It's wasteful of space, but the output of mp3 players seems to be better quality.
    You could play TZX and TAP files directly with Tapir. Works for me all of the time, turbo loaders included. As suggested by Zom, you will also need to drive the signal through an amplified desktop speaker with a headphones output in order to make the Spectrum 'catch' it.
    Remember to disable any enhancements (reverb, equalization etc.) your soundcard control panel, if present, could apply to affect the output.
    ramsrc wrote: »
    The noise of the worst soundcard is much lower than that of an old tape recorded from Spectrum. These old tape recorders often use DC current for the erase head. Especially the DC premagnetizing used at that recorders produces a noticeable big amount of noise. Nevertheless that tapes can be read from any spectrum computer.
    The problem is the low level only. There a two principle ways to increase that level:
    1. You can use an amplifier. For example use an external active speaker with a headphone socket.
    2. Or you can use a small transformer for example with a ratio of 1:4. In that case you don't need a power supply to increase the level.
    I did successfully load programs from soundcard of a notebook using an active speaker with headphone output.
    Greets Ingo.
    ingo wrote: »
    On the other hand, it's not always a problem. The Soundblaster card in the computer I'm using now can output a signal with an amplitude quite a bit beyond what is needed by a Spectrum. The audio output from laptop computers is often much more feeble, though.
    its also possible your soundcard is inverting the waveform
    djgarf wrote: »
    That alone would not cause any problem.
    ingo wrote: »
    Thinking about it, you are right.
    When I think how much noise there used to be on third or forth generation tape copies and they still worked.
    I have been using a Laptop, so perhaps I'll have to try on my desktop and see if that works any better with the larger output.
    To my experience, laptop PC audio output is weaker than that coming out from desktop PCs. Pre-amplification with a third device, even one as simple as a PC external loudspeaker, is unavoidable in this case.
    I use a jack to phono cable to connect desktop to stereo. My speccy is connected to the stereo, which is at 2/3 full volume. Doing it this way i can load games in a fraction of the time using k7zx 4.3. Before I added a ear socket to my +2A I used to use a cassette to mp3 player (tape with jack), from the stereo to tape deck of +2A, for this tap2wav was best
    djgarf wrote: »
    I had this problem with SiS 6326 and SiS 530 chipsets. The waveform was inverted, started negative.
    pkersey wrote: »
    The tape load routine only measures the duration between zero crossings without caring about phase information. The tape recorders also output randomly first a positive or a negative half wave.
    Greets ingo.
    ingo wrote: »
    Greets ingo.
    Thanks Ingo.
    Just to clarify. Actually never had a go with these chipsets and a Speccy. Just pointing that these chips reverse the waveform. They're Old chipsets though.
    I failed at trying to load from a PC although never actually tried a second time. To load programs I use a divIDE, a tape recorder or a mp3 player equalized the best as I could. Not all programs load from the mp3 player though. Just like the old days.
    So, this is what i find odd.
    My friend has a bunch of spectrums. We found only a +3 to work, so I couldn't try another 48k. But anyway, I loaded a game from my laptop first attempt using a stereo jack lead.
    I'll have to try again when I get home to my 48k...
    vext01 wrote: »
    Don't forget that for a 48K Spectrum at least, you should use a lead of the type I described earlier in the thread. A stereo to stereo or mono to mono audio lead will cause problems if used between a Spectrum and the stereo output of a PC/audio player etc. (It'll short the two channels together).
    I never did it from a PC but perhaps this might help. These are pictures showing how I connect my mp3 player to the Speccy's. One of the pictures show a stereo to mono cable (stereo end to be plugged to the mp3 device).
    The other pictures shows the equalization setup I'm using. If someone knows how I could do it better, please let us know. This is the best I came up with.
    http://www.flickr.com/photos/rdkarlov/sets/72157631780836860/
    Thanks for everyone's advice so far.
    I have built the cable to Zorn's specifications, but that alone is not enough. Seems i need to amplify the signal, or I could try (as others have), MP3 players or phones as an audio source.
    Will let you know how I get on.
    You can use power speakers as signal amplifier, however I'm using Thinkpad laptop as player and it works ok.
    You may check also EAR socket for contact quality-this is often source of the problems (signal is weak or disappears). I had such 128k recently.
    Following on from my last post, I have managed to get tape loading working quite satisfactorily.
    As was mentioned, the sound level from my Laptop is far too low to load successfully.
    I've been using WinTZX and it works pretty well most of the time. However, there does seem to be a bug when selecting files, so I am off to try Tapir!
    Zorn wrote: »
    I occasionally use (one half of) of the original Speccy tape lead to load PlayTZX audio files from the headphone socket of my laptop to the EAR socket of the Spectrum. Am I putting my hardware at risk?
  • LCDLCD
    edited October 2012
    Zorn wrote: »
    Mono to mono do not short two channel together, but one channel to ground, and the same with Stereo to stereo which will be sorting one channel to ground in Speccys plug. This may cause problems with some unprotected PC Hardware, but I never had some.
    I use old ISA cards with Passive SPK Out settings because they have strongest output level. New PCI cards do not work because there is a kind of law which forbids too high output level on Earphone output (because some kids has ruined their ear input using too high volumnes).
    Danforth wrote: »
    I did this sometimes while researching several ways of loading TZX files played with Tapir on the two PCs I own. It caused no harm at all.
    Again, all Spectrums require some sort of external amplification when loading files other than from physical tapes, especially the 16K/48K/+/128K, because they must be fed a very strong signal, otherwise they won't "catch" it.
  • utzutz
    edited October 2012
    I've fiddled quite a bit with loading stuff from PC. so here are a couple of things I've learned in addition to what has been said before:
    - Desktop PC soundcards usually have a Line Out, while Laptops normally have a Headphone Out only. Headphone ports receive an extra boost, which means that at high volumes, the signal will be distorted (if it isn't too quiet in the first place)
    - Desktop PC soundcards mostly work well, no extra amplification required.
    - Most external USB soundcards work well, too.
    - My personal favorite are regular CD players (not portable ones) - they have a very clean signal and are always loud enough, and don't require additional amplification. Plus, they normally have RCA ports, which elegantly solves the problem of converting from stereo to mono.
    cheers,
    -utz
    A mono-mono lead most likely works for tape loading however it connects the right hand stereo channel to ground inside your sound card. This may be fine or it may damage the output amplifier on the soundcard. Just because it doesn't harm one doesn't mean it won't damage someone else's. The risk of damage does seem to be fairly low.
    A stereo-stereo lead usually doesn't work properly at all as the way the mono socket in the speccy is constructed means that the right channel is being grounded again but this time to the speccy's ground, while the actual sleeve of the jack is left floating. This means that the circuit relies on there being a ground return besides the the audio cable outer (since it's not connected at the speccy end). If you are using a batter operated cd player, or a laptop obviously there can't be one. Even if both the source and the speccy are both connected to the mains that doesn't necessarily mean that their grounds are both at earth potential, there can also be a lot of noise introduced this way which will disrupt the loading.
    TL;DR version: it's best to just make up the correct lead in the first place, but if you must use the wrong thing then a mono-mono will have the greater chance of success.
    For a proper tape loading cable simply connect a stereo jack to a mono jack tip to tip and sleeve to sleeve, leaving the ring of the stereo jack unconnected.
    [FONT=Courier New]
    PC soundcard line out           Speccy ear socket
     T R  S                                   S   T
     _______.-------.              .--[/FONT][FONT=Courier New][FONT=Courier New]-----.[/FONT][/FONT][FONT=Courier New][FONT=Courier New][FONT=Courier New]_______
    [/FONT][/FONT]<_|_|___|       |--------------|[/FONT][FONT=Courier New][FONT=Courier New]       |_____|_[/FONT]>
            '-------'              [/FONT][FONT=Courier New]'-------'
    [/FONT]
    Obviously the same cable can be used between the line in and Mic to record saving tones from the speccy too.
    Not from my old cmedia PCI soundcard they didn't. I have a feeling that I can load from the onboard HDAudio in this PC too if I configure the output as a line out but I can't remember when I last loaded anything by tape into the 48k.
    Line out would be too low a signal, headphone out on some PCs might work though!
    I bought a little amp board off ebay and wired it up to an old 9v mains supply, then soldered on the correct leads on either side (pretty much what guesser's diagram above shows, but with an amp in the middle).
    course I should probably mention at this point that the +2A/+3 motherboard has a different arrangement and hence uses different leads. If you happen to have an original +3 tape lead lying around you can also use (half of) that to load into your 48k.
    Just plug the stereo jack (+3 end) into your soundcard and one of the mono jacks (tape deck end) into the ear socket.
    If you want to load into a +3 from the PC you have the same issues as with the 48k i.e. the +3 tape leads have mono jacks at the tape deck end. Again you can plug these in to the PC and probably get away with it however if you never plan to use the lead with a real tape deck again I would personally change the jacks for stereo ones. Again connect the signal wire to the tip and the braid to the sleeve, leaving the ring disconnected.*
    *If you want to use this lead to get the audio out from the AY etc to use with a composite modded +3 or an RGB monitor you can join the tip and ring together on the "Mic" lead half of the cable so that the audio from the speccy goes in on both channels. In fact you can do that for the Mic lead on the 48k too. Technically speaking you shouldn't do this with the Ear lead as this connects both channel outputs together in the soundcard though I've never known it do any harm.
    RobeeeJay wrote: »
    Hrm, what threshold voltage does the speccy need? I suppose you're right as looking at the schematic there's a 1k resistor sitting across the input so the line level will be below 2V.
    Perhaps I configured as a headphone/speaker output then :D
    You are of course quite right that turning the headphone amp on will deliver a greater voltage across a high impedance input. I was just being dim.
    Considering that both 3.5mm stereo and 3.5mm mono jack plugs are inexpensive and widely available from electronic suppliers (including Maplin, Bowood-electronics, plus the bigger suppliers) for as little as 35 pence each, why take the risk of causing damage to your Speccy, sound card or laptop?
    Some sound cards and laptops will use a audio amplifier chip that has short circuit protected outputs, but not all are rated to handle a continuous short circuit.
    If you cannot solder, ask nicely and I am sure someone will build a cable for you.
    It's about half-an hours work (not including ordering parts and trip to the post office / post box).
    guesser wrote: »
    I have been working with audio codecs/amplifiers for a few years now and one pretty universal feature is short circuit protection. I doubt you will find a singled consumer device these days that can be damaged.
